January 18, 2022, 07:55 |
alpha.water boundary condition
Rep Power: 4 |
hello i am a beginner of openfoam!
i am studying the example related the water injection. in this situation, i have a question.. I set the water injection amount to change with time by using code as mentioned below. (velocity(U) boundary condition) Code:
boundaryField { inlet1 { type flowRateInletVelocity; volumetricFlowRate table ( (0 2) (50 2) (50.01 0) (100 0) (100.01 2) (150 2) (150.01 0) (200 0) (200.01 2) (250 2) (250.01 0) ); } thank you ! Last edited by Tobi; January 18, 2022 at 08:56. Reason: Updated the formatting |
January 18, 2022, 08:55 |
Tobias Holzmann
Rep Power: 52 |
Depending on the real case, you could switch alpha between 0 and 1, similar to your U condition. So if no flux is going into your domain, set alpha to 0 or apply a zeroGradient BC. For that you would need to integrate a codedMixed boundary condition and use a switch between Neumann and Dirichlet based on, e.g., the time data or the velocity values at the patch faces.
Keep foaming, Tobias Holzmann |
multiphaseEulerFoam FOAM FATAL IO ERROR | qutadah.r | OpenFOAM Running, Solving & CFD | 11 | December 10, 2021 21:18 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 14:55 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
