Combustion hangs after a while - XiFoam
Old   January 18, 2022, 00:25
Post Combustion hangs after a while - XiFoam
Dilshan Casseer
casseer15 is on a distinguished road
Hello
I'm trying to simulate H2 combustion with air. domain has two regions- inner with fuel and air, outer without fuel.
I'm using XiFoam with Janaf themo and Sutherland transport model. Momentum transport is LES.
I have used inhomogenous mixture, so that I can set the ft to zero in the outer region, using setfields.
The issue is the combustion hangs after some time. The parameters U, P and T changes with time, but b is frozen in time. Nothing changes.
I have tried adjusting Janaf polinomials, Sutherland Coefficients, using different momentum transport models (LES, RAS) etc, but nothing seem to work. below is an image of b after it hangs (t=0.2 milliseconds). It does not develop beyond this point. I tired different ignition strengths and diameters too. It doesn't seem to make a difference.
Can anyone kindly point me in the direction in what I might be doing wrong.
I have attached the case setup can be found here in zip format.
casseer15 is offline   Reply With Quote
combustion, les, openfoam, xifoam
XiFoam combustion approach naman_jain OpenFOAM Running, Solving & CFD 0 June 14, 2016 04:30
XiFoam lean-premixed combustion instabilities remir OpenFOAM Running, Solving & CFD 8 April 15, 2016 09:31
combustion, XiFoam, ignitionSphereFraction achinta OpenFOAM 1 July 30, 2012 07:40
Turbulent combustion error... XiFoam model achinta OpenFOAM 1 July 7, 2010 09:24
Turbulent premixed combustion error... XiFoam model achinta OpenFOAM 1 June 23, 2010 06:45
