Rep Power: 13 ![]() |
When I try to run the sphereDrop example in OpenFOAM v2106 and v2112, I immediately get an error:
Maximum number of iterations exceeded: 100 when starting from T0:300 old T:5.593010375e+14 new T:5.593010375e+14 f:2.346267852e+18 p:82949.12625 tol:0.03 |
Yann
Rep Power: 27 ![]() |
Can you give more details?
The compressibleInterDyMFoam sphereDrop tutorial runs fine for me on v2112 on WSL. Yann |
I'm running it on Ubuntu 21.10. I have made no changes to the case files. I tried to run it in both serial and parallel with the same results.
Yann
I'm sorry I cannot really help much here since I don't have Ubuntu 21.10 running in order to reproduce your problem.
Did you compile OpenFOAM yourself or did you install the precompiled packages with apt? Yann |
dynamic mesh |
Porous media coefficients and working fluid | Dronzer | FLUENT | 1 | June 30, 2020 22:23 |
findCell() in parallel: not working if location is outside the domain | TobiWol | OpenFOAM | 0 | January 10, 2018 14:33 |
Processor 0 not working | vishwesh | OpenFOAM Running, Solving & CFD | 0 | November 17, 2017 03:35 |
DPM parallel is not working but serial is working | johnwinter | FLUENT | 1 | March 27, 2012 02:01 |
Working directory | mgonzalo | FLUENT | 1 | November 11, 2011 10:05 |
