CHT transient solver not converged beacuse of temperature dependent density
Old   December 29, 2021, 08:32
Default CHT transient solver not converged beacuse of temperature dependent density
lee wei
KKlee is on a distinguished road
Hi, Foamers,
I encountered a non converged problem when I used chtMultiRegionFoam for a steadystate solution.
The geometry is shown as the attached geometry picture,except for the hydrogen flow channel, the others are solid structures. when I set the Hydrogen density as constant, the case runs well, but when I changed it to a polynominal formal, the case will crashed because of the negative temperature. (For simplicity, I did not turn on the heat source)
fvScheme fvSolution and thermalProperties settings of Hydrogen are as following:
fvScheme:
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,h)      Gauss limitedLinear 1;
    turbulence      Gauss limitedLinear 1;
    div(phi,k)      $turbulence;
    div(phi,epsilon) $turbulence;
    div(phi,omega) $turbulence;
    div(phi,K) $turbulence;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear limited 0.5;
    //laplacian((rho*nuEff),U)    Gauss linear corrected;
    //laplacian(alphaEff,h)       Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
wallDist
    method meshWave;
fvSolution:
solvers
    rho
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-7;
        relTol          0.1;
    rhoFinal
        $rho;
        tolerance       1e-7;
        relTol          0;
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-8;
        relTol          0.01;
    p_rgh
        solver           GAMG;
        tolerance        1e-7;
        relTol           0;
        smoother         GaussSeidel;
    p_rgh
        solver           PCG;
        preconditioner
        preconditioner	GAMG;
        tolerance        1e-7;
        relTol           0;
	nVcycles 	 2;
        smoother         DICGaussSeidel;
	nPreSweeps	2;
	nPostSweeps	2;
	nFinestSweeps	2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
        tolerance        1e-7;
        relTol           0;
        maxIter          100;
    p_rghFinal
        $p_rgh;
        tolerance        1e-7;
        relTol           0;
    "(U|h|k|epsilon|R)"
        solver           PBiCGStab;
        preconditioner   DILU;
        tolerance        1e-7;
        relTol           0.1;
    "(U|h|k|epsilon|R)Final"
        $U;
        tolerance        1e-7;
        relTol           0;
PIMPLE
    momentumPredictor   yes;
    nCorrectors         4;
    nNonOrthogonalCorrectors 2;
    rhoMax          57.26;
    rhoMin          0.348388;
    pRefCell          0;
    pRefValue         4e6;
relaxationFactors
    equations
        "h.*"           1;
        "U.*"           0.7;
    fields
        rho             1;
        p_rgh           0.3;
thermalproperties:
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
    energy          sensibleEnthalpy;
mixture
    // coefficients for Hydrogen
    specie
        molWeight       2;
    equationOfState
     //   rhoCoeffs<8>    ( 2 0 0 0 0 0 0 0 );
        rhoCoeffs<8>    ( 2.028571 -0.000029 0 0 0 0 0 0 );
    thermodynamics
        Hf              0;
        Sf              0;
        CpCoeffs<8>     ( 19304 -21.912 3.3433e-2 -2.1053e-5 5.8506e-9 -5.4377e-13 0 0 );
    transport
        muCoeffs<8>     ( 4.3563e-6 1.3319e-8 -2.0504e-12 3.2893e-16 -1.5746e-20 0 0 0 );
        kappaCoeffs<8>  ( 0.21475  -4.5995e-4 1.2216e-6 -6.9773e-10 1.3786e-13 0 0 0 );
The 0 and log files are provided in the attached zone.
Any comments or suggestions are welcome since I've been stuck here for too long. Thanks in advance.
lee
KKlee is offline   Reply With Quote
Old   March 1, 2022, 10:21
Praharsha Reddy
lonewanderer is on a distinguished road
Hi Lee,
1. Check if you defined interfaces correctly. Because after seeing your log file i observed that there are missing interfaces.
2. Please also check boundary conditions.
3. Turn off functions inside controlDict.
lonewanderer is offline   Reply With Quote
2 Questions about Density Based Solver rap7or FLUENT 3 August 3, 2018 03:40
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Warning 097- AB Siemens 6 November 15, 2004 05:41
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
