refineMesh issues
Old   December 7, 2021, 12:19
Exclamation refineMesh issues
Eric Segalerba
EricS is on a distinguished road
Hi everybody,
I'm currently working on a quite complex geometry and to avoid both a too fine background mesh and a too high level of refinement, I'm trying to improve the background mesh on the external surface of my body (using refineMesh) and then use that as a background mesh.
That process works fine but then, when I use snappyHexMesh I got some errors that depends on the polyhedric cells that appear in the background mesh after the refinement.
I was wondering if there's a way to use >refineMesh and get only hexes from that.
Thank you in advance!
EricS is offline   Reply With Quote
hexes, polyhedral mesh, refinemesh, snappyhexmesh
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 3 February 18, 2016 21:09
[blockMesh] Multi-region Blockmesh - Refinemesh issues. Doug68 OpenFOAM Meshing & Mesh Conversion 0 February 17, 2016 04:39
[mesh manipulation] multiple calls to refineMesh parallel w/ dict failing Regis_ OpenFOAM Meshing & Mesh Conversion 2 June 4, 2015 14:44
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 17:18
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
