Problems validating fvOption solidficationMeltingSource using simple Stefan-Problem
Old   December 7, 2021, 08:19
Default Problems validating fvOption solidficationMeltingSource using simple Stefan-Problem
foxcfd is on a distinguished road
Hi guys,
I am trying to simulate the phase transition from water to ice using
buoyantPimplefoam and the fvOption solidificationMeltingSource.
Using this i created a simple Stefan-Problem consisting of adiabatic
walls and a single fixed temperature wall. As the temperature of this
wall is lower than the liquid, the liquid start to freeze.
I have the problem that the analytical and numerical data do not match.
I have attached several files, the first two images are my thermophysical
properties and my fvOptions file and the third image shows the simulation
progress, top is the temperature and bottom is the phase fraction of liquid/ice.
0 stands for ice whereas 1 stands for liquid. Lastly the comparison between
the simulated and numerical results.
Does anyone have an idea what could have caused the difference
between the two solutions? The exact same values from the simulation
were used to calculate the numerical solution.
Thanks in advance.
File Type: png Screenshot from 2021-12-07 13-01-15.png (53.5 KB, 18 views)
File Type: png Screenshot from 2021-12-07 13-01-56.png (49.9 KB, 14 views)
foxcfd is offline   Reply With Quote
Old   December 8, 2021, 06:22
Default Timestep and Mesh
Hi everyone,
just a quick follow up. I have significantly reduced
my mesh and time step, which has resulted in my
numerical solution approaching that of the analytical
one. I assumed that mesh and my time step would
be fine enough, but that was apparently not the case.
fvoptions, phase change, stefan problem
[solids4Foam] Problems while validating Turek and Hron (2006) FSI2 and FSI3 problems in solids4Foam subhasisa.rath OpenFOAM CC Toolkits for Fluid-Structure Interaction 0 September 6, 2021 18:02
Problem with FsiFOAM simulation of beams (2-4 beams) in a steady simple shear flow Aliiiii OpenFOAM Running, Solving & CFD 1 February 27, 2019 13:26
Stefan Problem : Tin Melting : Moving Boundary swparth OpenFOAM 0 September 21, 2017 15:53
Very simple combustion problem. Jouch FLUENT 4 October 21, 2004 23:28
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 10:11
