Sod shock tube using dsmcFoam - Help
Old   December 5, 2021, 13:23
Default Sod shock tube using dsmcFoam - Help
Melania
mely is on a distinguished road
Hi everyone!
I'm trying to simulate the Sod shock tube using the particle-based method called dmscFoam.
I'm new with OpenFOAM and C++ language, so I'm having some trouble using it.
I've set the initial conditions of pressure,density and temperature but the results are not the expected ones.
Did anyone try to do this simulation?
if someone can help me, I would appreciate it.
Thank you so much!
mely is offline   Reply With Quote
Old   December 15, 2021, 23:38
XJ YANG
xjyang is on a distinguished road
In sod shock tube problem, the density, velocity, and temperature is macroscopic variables, and the reference solution is calculated by Riemann solver; while DSMC is a particle method, which is mainly used in rarefied flow. If the DSMC method is used for the problems in continuum flow, a lot of particles is needed. So, why use DSMC solver for the sod shock tube problem?
xjyang is offline   Reply With Quote
Old   December 17, 2021, 12:13
Melania
Hi xjyang, thank you for answering!
This is actually a work for my master thesis: I'm trying to simulate basically a continuum flow with this discrete method. I know about the amount of particles that have to be used for the simulation. Do you have any tip?
You would be really helpful, since I'm having some trouble with the solver and I'm new with OpenFOAM.
Old   December 18, 2021, 10:47
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
A validation tutorial of Sod's shock tube using rhoPimpleFoam:
http://www.wolfdynamics.com/tutorials.html?id=150
Hope this helps a bit (though not direct answer to your questions)
HPE is offline   Reply With Quote
dsmc openfoam dsmcfoam, help needed, shock tube problem, sod shock tube
Solution of SOD Shock Tube Problem by using HARTEN Modified Flux TVD Scheme xue sheng Main CFD Forum 5 August 27, 2022 08:06
Sod Shock Tube solution using Nodal DGFEM 2D CNS Solver Quasar_89 Main CFD Forum 0 July 30, 2016 09:22
Euler Equations, Sod shock tube & conservation Antigravity System Analysis 1 July 17, 2014 14:30
Sod shock tube problem with real gas effects ganesh Main CFD Forum 0 October 17, 2006 02:22
SOD shock tube problem Luuk Main CFD Forum 3 September 6, 2005 06:08
