Implementation of git repos in Docker
Old   November 8, 2021, 11:44
Default Implementation of git repos in Docker
Callum Guy
CallumG is on a distinguished road
Hi All,
I use a number of third party git repositories for my OpenFOAM projects which in the past I have compiled directly on the HPC. Because of the ever increasing number of these I thought it would be perhaps better to creater a docker image that has everything already built and then just start new containers everytime I want to run something on the HPC. Firstly, does anyone already do this and how do you find it?
Secondly could anyone offer some advice on the Dockerfile? I found the one from Robin over at CFD Engine (thanks Robin!):
FROM ubuntu:focal
ENV DEBIAN_FRONTEND=noninteractive
RUN apt-get update \
	&& apt-get install -y vim curl git sudo
RUN useradd --user-group --create-home --shell /bin/bash foam ;\
	echo "foam ALL=(ALL) NOPASSWD:ALL" >> /etc/sudoers
RUN curl -s https://dl.openfoam.com/add-debian-repo.sh | bash ;\
	apt-get install -y openfoam1912 openfoam1912-tutorials ;\
	rm -rf /var/lib/apt/lists/* ;\
	echo "source /usr/lib/openfoam/openfoam1912/etc/bashrc" >> ~foam/.bashrc ;\
	echo "export OMPI_MCA_btl_vader_single_copy_mechanism=none" >> ~foam/.bashrc
USER foam
if I wanted to clone a repo and then make it with the above how would I implement that? Something like:
FROM ubuntu:focal
	echo "export OMPI_MCA_btl_vader_single_copy_mechanism=none" >> ~foam/.bashrc ;\
	git clone <git-repository> ;\
	cd <git repository> ;\
	./allwmake
USER foam
Be interested to discuss how others implement this kind of thing.
All the best,
Callum
CallumG is offline   Reply With Quote
Ansys Installation on Docker Container mohsen.shiea ANSYS 11 March 14, 2024 12:18
OpenFoam in docker (gcc 6) vs. OpenFoam natively compiled (gcc 8.1.1) Anouk OpenFOAM Running, Solving & CFD 0 September 17, 2018 09:02
[OpenFOAM.com] Docker vs Not Docker v2 AND installing editors into Docker u2berggeist OpenFOAM Installation 1 July 10, 2018 03:58
[OpenFOAM.com] v1606+ Install pb with Docker on OSX El Capitan BPich OpenFOAM Installation 3 October 10, 2016 19:52
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker rt08 OpenFOAM Installation 1 February 28, 2016 20:00
