An awkward issue
Old   October 29, 2021, 09:06
Default An awkward issue
Sandro Brad Martinez Sardon
sandrobrad is on a distinguished road
First of all ,I'm a little newbie using Openfoam9 and right now I'm trying to simulate a flow around a NACA0012 using SA turbulence model.
I'm having some issues when I want to write and monitor the fields nu and nut, nuTilda using the function turbulenceFields located in the controlDict:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime        10000;
deltaT          1;
writeControl    timeStep;
writeInterval   100;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    turbulenceFields1
        type        turbulenceFields;
        libs       ("libfieldFunctionObjects.so");
        fields
            k
            nut
            L
	executeControl  writeTime;
	writeControl    writeTime;
    forceCoeffs
	    type            forceCoeffs;
	    libs            ("libforces.so");
	    timeInterval    1;
	    log             yes;
	    patches         (airfoil);
	    rho             rhoInf;      // Indicates incompressible
	    rhoInf          1.225;           // Redundant for incompressible
	   liftDir (0 1 0);
	   dragDir (1 0 0);
	    liftDir         (-0.08715574275 0.9961946981 0);
	    dragDir         (0.9961946981  0.08715574275  0);
	    CofR            (0.72 0 0);  // Axle midpoint on ground
	    pitchAxis       (0 1 0);
	    magUInf         51.4815;
	    lRef            1;        // Wheelbase length
	    Aref            1.2944;        // Estimated //span= 0.6472197728*2 -> Aref = c*span;
	    binData
		nBin        20;          // output data into 20 bins
		direction   (1 0 0);     // bin direction
		cumulative  yes;
    yPlus1
        type        yPlus;
        patches         ("airfoil");
Even though the mesh quality is good , when I start the simulation the following message pop up:
Create time
Create mesh for time = 0
SIMPLE: Convergence criteria found
        p: tolerance 1e-05
        U: tolerance 1e-05
        nuTilda: tolerance 1e-05
        "(k|epsilon|omega)": tolerance 1e-06
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model SpalartAllmaras
Selecting patchDistMethod meshWave
RAS
    RASModel        SpalartAllmaras;
    turbulence      on;
    printCoeffs     on;
    sigmaNut        0.66666;
    kappa           0.41;
    Cb1             0.1355;
    Cb2             0.622;
    Cw2             0.3;
    Cw3             2;
    Cv1             7.1;
    Cs              0.3;
No MRF models present
No fvModels present
No fvConstraints present
Starting time loop
turbulenceFields turbulenceFields1: storing fields:
    nut
    k
    L
forces forceCoeffs:
    Not including porosity effects
forceCoeffs forceCoeffs:
--> FOAM FATAL ERROR:
attempted assignment to self
    From function void Foam::DimensionedField<Type, GeoMesh>::operator=(const Foam::DimensionedField<Type, GeoMesh>&) [with Type = double; GeoMesh = Foam::volMesh]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/DimensionedField.C at line 535.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::DimensionedField<double, Foam::volMesh>::operator=(Foam::DimensionedField<double, Foam::volMesh> const&) in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#3  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::operator==(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#4  void Foam::functionObjects::turbulenceFields::processField<double>(Foam::word const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5  Foam::functionObjects::turbulenceFields::execute() at ??:?
#6  Foam::functionObjects::timeControl::execute() at ??:?
#7  Foam::functionObjectList::start() at ??:?
#8  Foam::Time::run() const at ??:?
#9  Foam::Time::loop() at ??:?
#10  ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
#11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12  ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
Aborted
And now is questions time :
1.
attempted assignment to self What does that mean?
2.
where should I start to watch in order to know whats going on?
3. Exta info : If i comment this specific part of the control dict the code works fine, so the issue is related with the use of the turbulenceFields function.
 turbulenceFields1
        fields
            k
            nut
            L
Therefore, could you tell me how to fix that error?.Don't hesitate to ask me if you need more info about my case. Thanks in advance.
sandrobrad is offline   Reply With Quote
Old   November 5, 2021, 08:27
NiklasW is on a distinguished road
in general self assignment means that you are trying to assign a variable to itself, something like:
int x = 5;
x = x;
In your case this error might be caused if you are trying to store a field which is already stored in the database under the same name.
Suggestions for solving the issue:
1.) Find out if some of the fields are already stored and if so, remove them from your field list
2.) If this doesn't help, add the following line to your turbulenceFields subdict:
prefix true;
With this, the fields will be stored under a different name.
3.) I assume you also want the fields to be written in the time folders. I think this requires you to use the writeObjects function object additionally.
Hope this helps.
NiklasW is offline   Reply With Quote
Issue on zeroGradient BC for system rotation magnushaese OpenFOAM Running, Solving & CFD 2 January 28, 2022 14:43
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) kmkb21 OpenFOAM Running, Solving & CFD 1 March 1, 2018 02:07
Prism Layer - Core Mesh Boundary Issue InfernoxCJC STAR-CCM+ 7 November 21, 2017 16:46
foamToTecplot360 issue with multiregion solvers manuc OpenFOAM Post-Processing 2 November 21, 2016 14:51
Pressure boundary condition issue Vijay FLUENT 0 April 6, 2012 14:35
