Start simulation at t =/= 0 for oscillation motion
Old   October 20, 2021, 06:59
Default Start simulation at t =/= 0 for oscillation motion
worldsheep is on a distinguished road
Hello everyone,
I am running a simulation using pimpleFoam with a rotating oscillating mesh. I just found out that the rotating function is hardcoded in "oscillatingRotatingMotion.C" and is:
vector eulerAngles = ampltude_*sin(omega_*t)
Which means that the angular velocity goes as a cos function. This implies that my rotating element starts at full speed which is noti ideal for my application.
Conclusion: I would like to find a solution to start the simulation at rest and increase speed gently. Ideally I wiuld like a cos instead of a sin fot the angular position.
I found the following post:
AMI speed performance
But modifying the source code is not really an option for me.
My final question is... Is it possible to start a simulation at a time different than t = 0s? By properly choosing the initial time I could transform the sin function into a cos (phase shift).
worldsheep is offline   Reply With Quote
Old   October 20, 2021, 07:38
hxaxtma is on a distinguished road
1st option: Hard coded: it is possible but you need to adapt the solver. (e.g.: as an example define scalar t_offset -> (sin(t+t_offset))) and so on...
2nd option: Run "moveDynamicMesh" and stop at your wanted endTime of your initial stage. Next, run pimplefoam
Have fun
hxaxtma is offline   Reply With Quote
Old   October 20, 2021, 11:27
Thank you for your reply, I tried a third option which is a direct consequence of number (2):
3) Create a geometry with the rotor at the position which satisfies angular velocity equal to 0. Then change the name of the 0 folder into the time at which you want the rotor to have zero angular velocity (position is going to be -cos). Finally, change the controlDict and set:
startFrom       latestTime;
This has the advantage of keeping the position at wich angular velocity equals zero unchanged and have the amplitude as a parameter without needing to modify the geometry each time.
For the moment my simulation explodes,... Still trying to understand why
openfoam
mpirun during simulation under Docker (start with ./startOpenFOAM) spalartallmaras OpenFOAM Running, Solving & CFD 1 November 3, 2021 05:13
Cooling Brake Simulation: A Motion Problem Between Two Solid Interfaces SimulatorMaster Main CFD Forum 0 May 10, 2020 13:03
Start the simulation during a valve event MMatt CONVERGE 4 December 11, 2019 03:12
Start new Ansys Fluent Simulation automatically Malue Fluent UDF and Scheme Programming 1 October 4, 2017 02:48
Simulation with motion liuzexiang CFX 28 November 29, 2012 04:15
