Spline generation for Adjoint Based Shape Optimisation
Old   October 19, 2021, 09:13
Default Spline generation for Adjoint Based Shape Optimisation
radioactivity is on a distinguished road
I have a question regarding the adjointOptimizationFoam and in particular the shape optimization.
To train myself, I wanted to modify the example with the MotorBike to do modifications on a simple cube instead.
I set up my model and the cube seemed to deform itself at the front but the results were not at all what I was expecting : instead of rounding the edges and extending at the back, the cube was just shrinking in the direction of the flow or was getting a lot larger in width.
My question concerns the controlPoints of the volumetricBSplinesFI in particular. (Defined in 'constant/controlPoints')
For my own case I just took the same number of points as for the motorBike and just moved them in a manner to cover my own case better.
But when I change the number of controlPoints the log.adjointOptimisationFoam contains following error:
--> FOAM FATAL ERROR: (openfoam-2106) Number of control points does not agree with nCPsU*nCPv*nCPsW
I can't find any information on what those volumetricBSplinesFI and the numbers nCPsU*nCPv*nCPsW represent and in general very few information on the adjoint shape optimization algorithms of OpenFoam.
Does anyone has some more information on this topic or a solution on how I can use those control points more wisely ?
radioactivity is offline   Reply With Quote
Old   November 1, 2021, 01:11
Default need tutorial
Qureshi M Z I
m zahid is on a distinguished road
hello, hope you will be fine. actually i m interested in the adjoint shape optimization using openFOAM. could you please help me with some helpful material like tutorial. it will really help me to start learning this method. thanks in advance.
m zahid is offline   Reply With Quote
adjointoptimisation, adjointoptimisationfoam, adjointshapeoptimization, control points, openfoam 2106
CFD based robust hull shape optimization Thouelfaqar Main CFD Forum 0 October 13, 2011 15:44
SQP method for adjoint based aerodynamic shape optimization cfdbooks Main CFD Forum 2 May 26, 2009 11:40
laplace based grid generation prapanj Main CFD Forum 2 November 24, 2007 11:01
fan performance based on blade shape balaji Main CFD Forum 1 September 16, 2005 12:56
fan performance based on blade shape balaji Main CFD Forum 0 September 15, 2005 08:24
