October 2, 2021, 14:50 |
Convergence issue on NACA0012 simulation
Sandro Brad Martinez Sardon
Rep Power: 5 |
Hi there!
I am having some troubles trying to validate cd and cl numbers of naca0012 given the following boundary conditions using komegasst: k Code:
internalField uniform 3.98e-5;//funciona con 7.2599 boundaryField { inlet { type fixedValue; value $internalField; } outlet { type zeroGradient; } walls { type kqRWallFunction; //type kLowReWallFunction;//No es una wall function value $internalField; } frontAndBack { type empty; } } Code:
internalField uniform 1.10e-5; boundaryField { inlet { type calculated; value $internalField; } outlet { /* type calculated; value $internalField; */ type zeroGradient; } walls { type nutkWallFunction; value $internalField;//Valor muy pequeño por no poner 0 } "interface.*" { type empty; } } Code:
internalField uniform 3.62;//Esta bien este valor?//49701 funciona boundaryField { inlet { type fixedValue; value $internalField; } outlet { type zeroGradient; } walls { type omegaWallFunction; Cmu 0.09; kappa 0.41; E 9.8; beta1 0.075; value uniform 0.0035; } frontAndBack { type empty; } } Code:
internalField uniform ( 51.4815 0 0 ); //uniform (51.28559735 4.48690837 0); // ( Ubar*cos(5) Ubar*sin(5) 0) boundaryField { inlet { type freestreamVelocity; freestreamValue $internalField; } outlet { type freestreamVelocity; freestreamValue $internalField; } walls { type noSlip; } "interface.*" { type empty; } } The cl and cd values that I 've obtained is 0.00401141 0.011854 I am suspecting about the fvschemes and the fvsolution. Please , could you check out that files and tell me if that schemes are appropiate for my simulation? Control Dict Code:
application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 4000; deltaT 1; writeControl timeStep; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { momErr { type momentumError; libs (fieldFunctionObjects); executeControl writeTime; writeControl writeTime; } contErr { type div; libs (fieldFunctionObjects); field phi; executeControl writeTime; writeControl writeTime; } turbulenceFields1 { type turbulenceFields; libs (fieldFunctionObjects); fields ( k epsilon nut nuEff R devReff L I ); executeControl writeTime; writeControl writeTime; } mag1 { type mag; libs (fieldFunctionObjects); field turbulenceProperties:R; result magR; executeControl writeTime; writeControl writeTime; } forceCoeffs1 { type forceCoeffs; libs ("libforces.so"); writeControl timeStep; timeInterval 1; aoa 5; log yes; patches ("walls"); rho rhoInf; // Indicates incompressible rhoInf 1.225; // Redundant for incompressible liftDir (0 1 0); dragDir (1 0 0); /* liftDir (-0.08715574275 0.9961946981 0); dragDir (0.9961946981 0.08715574275 0); */ CofR (0.72 0 0); // Axle midpoint on ground pitchAxis (0 1 0); magUInf 51.4815; lRef 1; // Wheelbase length Aref 0.3; // Estimated /* binData { nBin 20; // output data into 20 bins direction (1 0 0); // bin direction cumulative yes; } */ } yPlus { type yPlus; libs (fieldFunctionObjects); writeControl writeTime; patches (wall); } cellCentres { type writeCellCentres; libs (fieldFunctionObjects); writeControl writeTime; } residuals { type solverInfo; libs (utilityFunctionObjects); fields (".*"); } } Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind;//linearUpwind grad(U); turbulence bounded Gauss upwind; //turbulence bounded Gauss limitedLinear 1; div(phi,k) $turbulence; div(phi,omega) $turbulence; div(phi,nuTilda) bounded Gauss linearUpwind grad(nuTilda); div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Code:
solvers { p { solver GAMG; tolerance 1e-06; relTol 0.01; smoother GaussSeidel; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0; } nuTilda { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.01; } "(k|epsilon|R)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-08; nSweeps 2; relTol 0; } omega { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-08; relTol 0; nSweeps 2; } } SIMPLE { nNonOrthogonalCorrectors 0; residualControl { p 1e-5; U 1e-5; nuTilda 1e-5; "(k|epsilon|omega)" 1e-6; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; epsilon 0.7; nuTilda 0.8; omega 0.7; } } |
October 3, 2021, 09:38 |
Michael Alletto
Rep Power: 16 |
Did you know this https://www.openfoam.com/documentati...irfoil-2d.html
October 3, 2021, 09:54 |
Michael Alletto
Rep Power: 16 |
If you need a discussion about how to simulate a wall resolved case with a k omega set you can look at this k-omega SST for wall-resolved TBL, problem with log layer..
For a y+ of 8 better use nutUSpalding b.c. since nutk is only valid in the log layer |
October 4, 2021, 06:17 |
Rep Power: 5 |
Hi Michael ,
I already know about that simulation. Moreover, that sim I've used it in order to learn how to use the SpalartAllmaras. Eventually, I was able to achieve good results using it. However, I'm trying to simulate with that boundary conditions (U,nu,rho...) using the kOmegaSST turbulence model.Like I said, using this model I'm getting trouble in the convergence. Thanks for ur reply btw. Best Regards. |
FSI: Convergence issue for a simple cylinder on top of a latex membrane | Geraud | CFX | 3 | November 23, 2014 17:02 |
Wind Tunnel Flow Simulation Mass Flow BC Issue | ledelman | SU2 | 4 | August 3, 2014 18:38 |
mass flow rate issue in supersonic nozzle simulation | xkang | FLUENT | 0 | July 31, 2014 16:06 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Heat Transfer simulation: No convergence problem | fiqs | CFX | 2 | April 21, 2010 15:47 |
