error when using DFSEM turbulent inlet
Old   September 27, 2021, 04:55
Default error when using DFSEM turbulent inlet
wangpeiyuan
O1Mania is on a distinguished road
I would like to use the boundary condition turbulentDFSEMInlet in the case tutorials/incompressible/pimpleFoam/LES/planeChannel/setups.orig/DFSEM of OpenFOAM v2106 .
The data files of points and U R L should be prepared first.
In my opinion, the points file contains all the points or nodes of the inlet surface.
So all the points and the corresponding datas of U R L are writen into the file.
But after running pisofoam, the error is reported as follows
Cannot find point in pts1 matching point 0 coord:(0 9.872974421 5.900000087) in pts0 when using tolerance 1e+15
Searching started from:0 in pts1
Cannot find point in pts1 matching point 155 coord:(0 -9.872974421 5.900000087) in pts0 when using tolerance 1e+15
--> FOAM FATAL ERROR: (openfoam-2106)
Did not find a corresponding sourcePoint for every face centre
    From void Foam::pointToPointPlanarInterpolation::calcWeights(const pointField&, const pointField&)
    in file triSurface/triSurfaceTools/pointToPointPlanarInterpolation.C at line 159.
FOAM exiting
After checking the code in tutorials again,I thought that the points file should contain the coordinates of the center of all cells .
So I changed the points file but the same error occured.
Has anyone encountered a similar problem?
Or the error is not caused by the points file but by other reasons?
Hope someone can help solve this problem, thanks very much!
O1Mania is offline   Reply With Quote
Old   October 14, 2021, 02:24
wangpeiyuan
can anyone help solve this problem?
Turbulent inlet fluctuation scale christian OpenFOAM Running, Solving & CFD 2 November 3, 2023 08:14
UDF for fully developed turbulent flow at inlet soroushsaberi FLUENT 0 May 28, 2014 18:00
Spatially Developing Turbulent Boundary Layer Inlet deji OpenFOAM 1 June 8, 2010 15:52
Specify turbulent inlet chris1980 OpenFOAM Running, Solving & CFD 4 August 29, 2006 04:11
inlet turbulent B.C. ROOZBEH FLUENT 3 September 25, 2003 08:07
