September 5, 2021, 17:17 |
Opensource library for ICE based on OpenFOAM
I'm looking for an opensource library (C++) based on OpenFOAM that simulates an internal combustion engine (mostly interested in reciprocating engines).
Searching online I found different papers from POLIMI (Politecnico di Milano) discussing a library called Lib-ICE which, apparently, does exactly what I need, but unfortunately doesn't seem to be opensource or available in any other form or shape. Is there something similar I'm not quite able to find? Thank you Last edited by lennox; September 6, 2021 at 07:32. |
September 15, 2021, 08:46 |
Tobias Holzmann
Rep Power: 52 |
Out of the box I only know the department you already mentioned. However, its more a consortium rather than only Politechnico. Last year I was able to join the ICE conference in Milano and the ICE library is more or less the "standard" way to go. Even though the ICE process itself is not a good one:
- Mesh the geometry - Move the mesh until it is distorted - Go back one step and extract the surface - Create new mesh with new surface (already moved one) - Map fields from old mesh to new one - Repeat until you are done However, this single steps are done via some scripts (combining mostly already existing applications existing in OpenFOAM). Hence, its IO expensive as the data are always re-saved and -loaded from the HDD rather than storing everything in the memory. I wanted to create something like that once by support from USA. I started and made some test but you have to manipulate a lot of classes and standard code (at least the way I wanted to go). To answer you question: - ICE from Politechnico is non-open-source - Once I found a talk from ... ( I cannot remember) but they have exactly the above workflow by using only Memory stuff - never found it and probably its non-open-source too (otherwise I would already be aware of it) - Anything else: no idea, hence, probably there does not exists any library for ICE Alternatives: oversetMesh or own development.
Keep foaming, Tobias Holzmann |
[Helyx OS] How can HELYX-Core be based on OpenFOAM? | HPE | OpenFOAM Community Contributions | 6 | June 26, 2020 09:22 |
Various problems compiling interFoam with CFDSupport's v1706 port of OpenFOAM | ndtrong | OpenFOAM Programming & Development | 9 | April 10, 2020 12:56 |
OpenFOAM Foundation releases OpenFOAM® 3.0.0 | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 1 | November 7, 2015 16:16 |
including third party GPU library in OpenFOAM | spelai | OpenFOAM Programming & Development | 3 | November 2, 2012 06:06 |
Others library application for OpenFoam 1.5 in Windows | lcnmy | OpenFOAM Installation | 2 | July 21, 2010 21:54 |
