September 2, 2021, 11:39 |
ccmToFoam error at v1912
Mehmet Alim
Hi foamers,
I want to convert a .ccm mesh file by STAR-CCM+ to OpenFOAM. In the OpenFOAM-v1912, there are two files in $FOAM_APP/utilities/mesh/conversion/ccm, ccmToFoam and foamToCcm, respectively. But when I want to execute the Allwmake file in ccmToFoam, there is an error "==> skip optional ccm conversion components (no libccm.so)". Need your help and wish your reply. |
January 28, 2022, 10:49 |
Rep Power: 6 |
Same problem with openFOAM 2112. I've downloaded the library libccmio-2.6.1 and placed in which seams to be the required folder
/usr/lib/openfoam/openfoam2112/platforms/linux64GccDPInt32Opt/lib/libccm/ Code:
$FOAM_LIBBIN/libccm |
April 29, 2022, 09:34 |
#3 | ||
Shenhui Ruan
Rep Power: 4 |
please read this thread, the solution of Mathieu works to me, I hope it also works for you.
I think the problem maybe there are some special settings in OpenFOAM compile which would relocate the libccm. But I don't know the details. Quote:
in the OpenFOAM compilation process, I find the following information, I don't know whether it is helpful. Quote:
[Commercial meshers] [OpenFOAM-v1706] ccmToFoam error | shuai_manlou | OpenFOAM Meshing & Mesh Conversion | 26 | May 13, 2024 02:13 |
different results form openfoam 3.0.1 to 1912 | yuno | OpenFOAM Running, Solving & CFD | 0 | September 28, 2020 03:09 |
OpenFOAM v1912 Green Water Loading Case Implementation Problem | leuthar | OpenFOAM Running, Solving & CFD | 2 | March 12, 2020 16:42 |
[OpenFOAM.com] Can't build ParaView in v1912 after changing from OpenFOAM.org (v7) | fanta | OpenFOAM Installation | 1 | February 24, 2020 04:35 |
[swak4Foam] Setting field with a zone() condition using OpenFOAM V1912 setExprField | stewaj5 | OpenFOAM Community Contributions | 0 | January 5, 2020 20:38 |
