August 18, 2021, 10:49 |
parallel run with cyclic acmi bottleneck
Rep Power: 8 |
hi all,
i am running a simulation with a mesh, which i created from two bodies independently. for the simulation i use cyclic acmi for the boundary at the transition surface. bc my case is rather large, i use multiple cores. however, i do not get the simulation to run faster with more than 30 cores bc i need to put the transition faces in one core. so my bottleneck is the cyclic acmi boundary that keeps all the faces in one core, and further usage of more cores does not lead to speed-up. does anybody have a tip or suggestion on how to improve the performance? thanks |
bottleneck, cyclic acmi |
[Salome] Salome import "Cannot find file "points" in directory..." | mismichael | OpenFOAM Meshing & Mesh Conversion | 6 | June 24, 2024 04:17 |
Lagrangian particle tracking cannot be run in parallel for the cases with AMI patches | Armin.Sh | OpenFOAM Running, Solving & CFD | 7 | March 28, 2021 23:33 |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 08:49 |
Problem in foam-extend 4.0 ggi parallel run | Metikurke | OpenFOAM Running, Solving & CFD | 0 | February 20, 2018 07:34 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 13:08 |
