Help: Calculation terminated but cannot find the reaon |
August 16, 2021, 10:59 |
cloud Wang
Hi all,
I want to simulate a simple case with a cylinder, which using a dynamic Mesh. I want the cylinder can rotate from a point. With rotation speed of 0 rad/s. The simulation went well. But when a positive rotation speed is added, the calcuation paused and terminated after serveal calcualtion step. In paraview, results of the steps which already perfromed looks fine. So I have no clue how to locate the reason of terminated of calucation. Can some one help me to find out the reasons? Many thanks! Following is the latest sentences from log file. Seems there is some non-zero values there but I do not how to find the reason. PIMPLE: Iteration 1 AMI: Creating addressing and weights between 7168 source faces and 7168 target faces AMI: Patch source sum(weights) min/max/average = 0.503673, 1.39448, 0.830561 AMI: Patch target sum(weights) min/max/average = 0, 1.38001, 0.776023 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.0189694, No Iterations 17 GAMG: Solving for pcorr, Initial residual = 0.502012, Final residual = 0.0103886, No Iterations 5 time step continuity errors : sum local = 7.28406e-11, global = -4.74792e-12, cumulative = -1.1844e-11 smoothSolver: Solving for Uy, Initial residual = 0.00250991, Final residual = 3.94283e-05, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.0020454, Final residual = 3.50647e-05, No Iterations 1 -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[37505,1],0] Exit code: 142 -------------------------------------------------------------------------- |
August 17, 2021, 05:40 |
The bold line below gives you the reason: Code:
PIMPLE: Iteration 1 AMI: Creating addressing and weights between 7168 source faces and 7168 target faces AMI: Patch source sum(weights) min/max/average = 0.503673, 1.39448, 0.830561 AMI: Patch target sum(weights) min/max/average = 0, 1.38001, 0.776023 GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.0189694, No Iterations 17 GAMG: Solving for pcorr, Initial residual = 0.502012, Final residual = 0.0103886, No Iterations 5 time step continuity errors : sum local = 7.28406e-11, global = -4.74792e-12, cumulative = -1.1844e-11 smoothSolver: Solving for Uy, Initial residual = 0.00250991, Final residual = 3.94283e-05, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 0.0020454, Final residual = 3.50647e-05, No Iterations 1 You can try and test this with moveDynamicMesh -checkAMI. Hope this helps. |
August 19, 2021, 11:30 |
cloud Wang
Hi, tomf, Thanks!
You are right. It is becasue of the mesh. Seems the snap in snappyHexMesh does not successfully applied. Now it works. |
"Hand" calculation jet fan in the garage | mageno | Main CFD Forum | 3 | August 7, 2021 20:09 |
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 09:05 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 04:07 |
[foam-extend.org] Installing foam-extend 3.1 on Ubuntu 14.04 | stephie | OpenFOAM Installation | 16 | April 23, 2015 17:18 |
Backtrace errors while running on a HPC with buoyantBoussinesqSimpleFoam | Thangam | OpenFOAM Running, Solving & CFD | 2 | July 12, 2014 00:39 |
