compressibleInterFoam Negative initial temperature T0
Old   July 27, 2021, 00:14
Default compressibleInterFoam Negative initial temperature T0
Solomon C is on a distinguished road
Dear Foamers,
I've been simulating a gas atomizer using compressibleInterFoam and have been getting the same error "Negative initial temperature T0" for days. Depending on my adjustments on the fvSchemes and BCs the simulation can run for at most several times e-5 s, but never beyond that.
My sketch for the geometry and the 1e-6 s image for velocity are attached. Similar settings I've tried produced similar results. The gas inlet velocity is set to be ~10m/s. Somehow the velocity explodes to several hundred meters, which doesn't make any sense.
I think the abnormal velocity caused the abnormal temperature so the key is the velocity?
Does anyone have any idea what may be the cause of this issue?
Thanks in advance,
Solomon
Solomon C is offline   Reply With Quote
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
