Groovy BC : time dependent boundary condition from a data table (timelines) |
Jordan EINRICK
Rep Power: 0 ![]() |
Hello everyone,
I am actually implementing a simulation in heat transfer with OpenFOAM 8. The geometry has an interface between the fluid (water) and the solid (iron) exchanging heat through it. Other boundaries are external boundaries on the solid region and are subject to convective heat fluxes with the ambient air. The main problem is the following, the heat exchange coefficient h in [W/mē/K] is time dependent and profile is stored in a data table. What I managed to do is to read a 'h.data' table and to run the simulation. Here after is the boundary condition on T I inputtedin 0/solid/T on the patch top: top { type groovyBC; variables "Tinf=350.0;lambda=44.5;"; timelines ( { name conv; outOfBounds clamp; file "h.data"; } ); gradientExpression "-h*(T-Tinf)/lambda"; fractionExpression "0"; value uniform 400; } What brought me to create this thread is that in the log.reconstructPar (parallel simulation) I find the error : Reconstructing FV fields Reconstructing volScalarFields T --> FOAM FATAL IO ERROR: keyword name is undefined in dictionary "/home/user/Desktop/testCase/processor0/0.001/solid/T/boundaryField/top/timelines" file: /home/user/Desktop/testCase/processor0/0.001/solid/T/boundaryField/top/timelines from line 59 to line 60. From function const Foam::entry& Foam::dictionary::lookupEntry(const Foam::word&, bool, bool) const in file db/dictionary/dictionary.C at line 797. FOAM exiting So what I understand is that there is a problem with the "timelines" keyword but i don't know why.Therefore, when I open it in paraFoam, I get the time 0 solution, but get a "T (?)" in SolidColor for t>0s. If you have any hint or piece advice for this matter, please feel free to get in touch Thank you very much in advance, Jordan PS: on the following link https://openfoamwiki.net/index.php/C...oovyBC#wobbler there is an example that inspired me for my boundary condition. Also concerning this wobbler test case, I couldn't find it on Google. |
boundary condition t, groovybc, tablefile, time-varying bc, timelines |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Time dependant pressure boundary condition | yosuke1984 | OpenFOAM Verification & Validation | 3 | May 6, 2015 06:16 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
