Wall Roughness and multiphase simulation
Old   July 19, 2021, 07:04
Default Wall Roughness and multiphase simulation
Mohamad Reza Salehi Sadaghiani
Mamadsaleh is on a distinguished road
Dear CFD-community,
I have set up a multiphase simualtion for a rectangular channel.
It works perfect (see zipfile "01_chennel_Mo_nut_0.02 - Kopie"). After that I just have changed the "nut" file for adding the roughness (Ks and Cs ...) and the simulation works for some timesteps and then it stops (see zipfile "02_chennel_Mo_nutkRoughWallF_ks_0.01"). The message is to long so I paste just an small part of it :
Courant Number mean: 0.160202 max: 5.84469
Interface Courant Number mean: 0.00963411 max: 4.0877
deltaT = 0.0029037
Time = 0.662252
MULES: Solving for alpha.water
Phase-1 volume fraction = 0.429972 Min(alpha.water) = -0.0460261 Max(alpha.water) = 1
Phase-1 volume fraction = 0.430009 Min(alpha.water) = -0.0641376 Max(alpha.water) = 1
Phase-1 volume fraction = 0.430045 Min(alpha.water) = -0.0762846 Max(alpha.water) = 1
GAMG: Solving for p_rgh, Initial residual = 0.0109182, Final residual = 3.54955e-05, No Iterations 2
time step continuity errors : sum local = 7.04264e-05, global = -3.02566e-06, cumulative = -0.00251685
Generating stack trace...
Backtrace:
ZN10StackTraceC1Ev [0x626c1855+0x25]
module: C:\PROGRA~1\BLUECF~2\ThirdParty-8\platforms\mingw_w64GccDPInt32\lib\libstack_trace .dll
ZN4Foam5error10printStackERNS_7OstreamE [0x6c30ae5a+0x23a]
module: C:\PROGRA~1\BLUECF~2\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM .dll
ZN4Foam6sigFpe13sigFpeHandlerEi [0x6c30b693+0x33]
(No symbol) [0x417202]
The Courant number is not so big. I changed the timesteps more than 30 times form bigger to smaller one and vice versa.
I have refined the mesh and changed the value of Ks. But at some place between .55 sec to 0.65 sec it stops.
Simulations can be downloaded hier:
https://drive.google.com/drive/folde...DE?usp=sharing
Any help will be appricated.
Last edited by Mamadsaleh; July 19, 2021 at 11:14. Reason: simulations could not be uploaded
Mamadsaleh is offline   Reply With Quote
Old   July 20, 2021, 06:08
Default Structured Mesh
I solved myself the problem. Taht was because of structured Mesh, which I used. I changed the mesh into unstructured and it works again perfectly.
roughness height
Divergence in AMG solver! marina FLUENT 20 August 1, 2020 12:30
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Multiphase simulation of bubble rising Niru CFX 5 November 25, 2014 14:57
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
