solids4Foam installation, foam-extend 4.0, ubuntu 18.04 |
July 17, 2021, 01:35 |
Alberto Campuzano
Rep Power: 5 |
Good night dear all
my name is Alberto, i ve been working with openfoam8. However, i noticed that i need solids4Foam, because of the FSI solver. i installed the foam-extended 4.0 and after the solids4Foam. However, i am facing an error that solids4Foam is not working, the solver does not appear. When i compiled foam-extended4.0 everything went well, (see attached file log.foam-extend-4.0.gz). but when i compiled the solids4Foam a problem appears saying Code:
recipe for target 'solids4Foam' failed to install foam-extended 4.0 i followed the instruction on the website https://openfoamwiki.net/index.php/I...u#Ubuntu_18.04 and for the installation of solids4Foam i just checked the pdf by Phillip Cardiff. on the website https://www.researchgate.net/profile...am-toolbox.pdf I hope you can help me. I have no idea how to solve the issue. Thanks in advance |
foam-extend 4.0, openfoam, solids4foam |
[foam-extend.org] foam-extend 3.2 Paraview installation problem on Ubuntu 18.04 | ordinary | OpenFOAM Installation | 3 | September 1, 2018 23:01 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 23:07 |
[Other] Problem in Open foam installation in ubuntu 14.04 | zannatul | OpenFOAM Installation | 2 | November 3, 2014 21:56 |
ParaView-4.0.1 did not compile for foam extend 3.0 installation | mhkenergy | OpenFOAM Installation | 8 | June 4, 2014 03:26 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
