ReactingFoam Issues
Old   June 26, 2021, 02:58
Unhappy ReactingFoam Issues
Carlos Alarcon
calarcon is on a distinguished road
I want to do a project of ignition of non premixed combustion for a course at the university. This is my first course of CFD and I'm a little lost
I follow this tutorial https://www.youtube.com/watch?v=BnykhP8olUk&t=655s so many times, and without success openfoam 7 openfoam 8 in ubuntu 20.04 and bluecfd in windows temperature goes out of 5000-6000 a lot of warnings of janaf and the result is don't enter fuel or air after calculation.
Chamber in the start is 2000 ° K and with time is cooling with cold air from outlet.
I don't have reactingMixture in thermophysicalPropierties on openFoam by defect use multiComponentMixture I don't know if this is the problem. Finally I tried to copy the mixed properties of SandiaD with worst result.
I guess can be mesh problems but it is the same that in the tutorial.
This is the last configuration with mass fractions of of SandiaD
https://drive.google.com/file/d/15Dl...ew?usp=sharing
Thank You in Advance
calarcon is offline   Reply With Quote
Old   June 26, 2021, 20:40
Carlos Alarcon
Solved i put the velocity in the opposite direction
reactingFoam crashes with no iterations uckmhnds OpenFOAM Running, Solving & CFD 3 July 17, 2022 19:41
How to switch off combustion and reaction in reactingFoam shenzhou1987 OpenFOAM Running, Solving & CFD 16 October 26, 2017 16:31
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 17:18
reactingFoam wedge handling wrong U dhondupant OpenFOAM Bugs 1 December 9, 2010 08:34
reactingFoam - turbulent reacting flow hamburgFoam OpenFOAM 0 December 7, 2009 13:57
