Adjustable timestep for settleling, then fixed timestep large eddy simulation |
June 15, 2021, 10:36 |
Malte
Rep Power: 9 |
I am running LES and URANS simulations in openFOAM. It is essential to settle the simulations fast and then to average with a courant-number < 1 (for the LES). The timestep has to be fixed in order to gain turbulence-data which can be used in FFT.
Is it possible to use an adjustable timestep based on the courant-number first and then define a fixed timestep based on the average timestep used in the first simulation interval? |
June 16, 2021, 00:09 |
Set' adjustTimeStep' to 'no'
Rahul Vadrabade
Rep Power: 8 |
If I understood requirements correctly,then probably changing 'adjustTimeStep' to 'no' should work, if solver support it. However, you have to calculate average delltaT, probably on your own. You can change this variable value anytime during simulation in controlDict and restart simulation.
Also, it is difficult or tricky to maintain courant number<1 with fixed time step. |
Large Eddy Simulation | Nijanthan | FLUENT | 14 | May 3, 2021 16:32 |
Introductory books on Large Eddy Simulation | q.z. | Main CFD Forum | 5 | September 20, 2016 06:32 |
Mean flow field in Large Eddy Simulation | Servantes | STAR-CCM+ | 1 | September 11, 2014 18:32 |
[LES]how to learn large eddy simulation from scratch alone? | yzeyue | Main CFD Forum | 8 | October 30, 2013 09:18 |
Large Eddy simulation | Andreas Hauser | Main CFD Forum | 1 | May 20, 2000 21:33 |
