Anjul Pandey
Rep Power: 6 ![]() |
Hello everyone, I am trying to make a cylindrical mesh with a square inside it. I wrote the blockMeshDict file, reviewed it but still couldn't figure out the issue. My blockMeshDict file is:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; // meters //Domain length Length 150; //Square inside cylinder Spoint 1.0; //Square point Mspoint -1.0; //Negative direction square point //Points of cylinder icpoint 10.0; //ic-> inner Circle Micpoint -10.0; //M-> minus //Interpolation points to make arc apoint 14.14213562; //arcpoint Mapoint -14.14213562; vertices ( //Bottom (0 0 0) //0 //Inner Square (0 $Spoint $Mspoint) //1 (0 $Mspoint $Mspoint) //2 (0 $Mspoint $Spoint) //3 (0 $Spoint $Spoint) //4 //Circle (0 $icpoint $Micpoint) //5 (0 $Micpoint $Micpoint) //6 (0 $Micpoint $icpoint) //7 (0 $icpoint $icpoint) //8 //Top ($Length 0 0) //9 //Inner Square ($Length $Spoint $Mspoint) //10 ($Length $Mspoint $Mspoint) //11 ($Length $Mspoint $Spoint) //12 ($Length $Spoint $Spoint) //13 //Circle ($Length $icpoint $Micpoint) //14 ($Length $Micpoint $Micpoint) //15 ($Length $Micpoint $icpoint) //16 ($Length $icpoint $icpoint) //17 ); //Mesh resolution Nsqy 20; //Number of cells in square in y direction Nsqz 20; //Number of cells in square in z direction Nax 100; //Number of cells in axial direction blocks ( hex (1 4 3 2 10 13 12 11) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1) hex (1 5 8 4 10 14 17 13) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1) hex (4 8 7 3 13 17 16 12) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1) hex (3 7 6 2 12 16 15 11) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1) hex (2 6 5 1 11 15 14 10) ($Nax $Nsqy $Nsqz) simpleGrading (1 1 1) ); edges ( //Bottom arc 5 6 (0 0 $Mapoint) arc 6 7 (0 $Mapoint 0) arc 7 8 (0 0 $apoint) arc 8 5 (0 $apoint 0) //Top arc 14 15 ($Length 0 $Mapoint) arc 15 16 ($Length $Mapoint 0) arc 16 17 ($Length 0 $apoint) arc 17 14 ($Length $apoint 0) ); boundary ( inlet { type patch; physicalType noParticleOutFlow; faces ( (1 2 3 4) (1 5 6 2) (2 6 7 3) (3 7 8 4) (4 8 5 1) ); } outlet { type patch; physicalType particleOutFlow; faces ( (10 11 12 13) (10 14 15 11) (11 15 16 12) (12 16 17 13) (13 17 14 10) ); } side { type patch; physicalType particleoutFlow; faces ( (5 14 15 6) (6 15 16 7) (7 16 17 8) (8 17 14 5) ); } ); mergePatchPairs ( ); /// ************************************************** *********************** // I am getting this error: --> FOAM FATAL ERROR: Inconsistent number of faces between block pair 0 and 1 From function void Foam::blockMesh::calcMergeInfo() in file blockMesh/blockMeshMerge.C at line 217. FOAM exiting Any help would be appreciated. |
Rahul Vadrabade
Rep Power: 8 ![]() |
I couldn't try at the moment but can you check that the topology of block is correct by defining a single hex block at a time, commenting other lines. Probably you can find clue to issue. To check blocks are correct, try 'paraFoam -block'. |
Anjul Pandey
Thank you for your response. I tried what you said and found out the issue. It's in the way I was giving the cells in each direction. The correct way is:
($Nsqy $Nsqz $Nax) in all hex cells as both Nsqy and Nsqz are 20. |
blockmesh dict, meshing 3d, openfoam 5.x |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
BuoyantBoussinesqSimpleFoam_Facing problem | Mondal131211 | OpenFOAM Running, Solving & CFD | 1 | April 10, 2019 19:41 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
