Spurious Values when Probing (u,v)?
Old   May 21, 2021, 15:16
Default Spurious Values when Probing (u,v)?
n/a
williamsj0165 is on a distinguished road
I am running a simulation that simulates the flow over three rotating cylinders. I am probing the velocity and pressure at several locations in the wake downstream of the cylinders.
When plotting the velocities in MATLAB, I notice what appear to be spurious values of velocity; see the attachment below. Although this case is not very extreme, some probe locations return many spurious values.
What could be the cause of this? Thank you for any thoughts or insight.
williamsj0165 is offline   Reply With Quote
Old   May 22, 2021, 10:24
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Are those probes close to any boundary (including processor boundaries if the case is parallel)?
Might be useful for the community if you can provide a minimal reproducible example. There could even be a bug.
HPE is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
Setting patch field values equal to internal field values leroyv OpenFOAM Programming & Development 1 October 21, 2014 16:49
Loading Cell Values in Tecplot P1361 OpenFOAM Post-Processing 3 September 16, 2014 05:02
Plotting raw data values Wilesco Siemens 0 January 5, 2006 06:34
