alphaSgs and muSgs
Old   May 20, 2021, 00:36
Default alphaSgs and muSgs
Niyas
niyas is on a distinguished road
Dear Foamers,
Recently I came across two files in the '0' folder called alphaSgs and muSgs. I checked online and I couldn't get much information.
Does anybody know what is mean by alphaSgs and muSgs ?
Thanks in advance,
Regards,
Niyas
niyas is offline   Reply With Quote
Old   May 20, 2021, 13:03
Tobermory will become famous soon enough
SGS = subgridscale, mu is the dynamic viscosity and alpha is the thermal diffusivity. So these files are the fields for the subgridscale (non-resolved) effective viscosity and thermal diffusivity in your LES simulation. If this is NOT an LES simulation, then you have a problem/intruder!
Tobermory is offline   Reply With Quote
Old   May 21, 2021, 09:18
Niyas
Hi Tobermory,
Thanks for your reply.
Yes. My simulation is LES.
Do you have/refer any material to study some basics of subgridscale ?
Regards,
Niyas
Old   May 21, 2021, 09:26
I would suggest starting with a simple google on "Large Eddy Simulation" ... the wikipedia article for example will walk you through the basics. Then search for some more detailed write ups, and look for academic publications of LES for a similar geometry/test case that you are trying to run. Read through a few online PhD theses, since these often lay out the fundamentals.
It's REALLY important to understand the difference between RANS and LES (resolution of scales, averaging times and sampling frequency, boundary conditions and initial conditions), if you are planning to do LES work - there are so many ways to fall down, compared to RANS modelling.
Old   May 31, 2021, 06:16
Niyas
Hi Tobermory,
Thank you very much for your reply.
I will work on it and update here in the thread if I have any further questions.
Regards,
Niyas
alphasgsm musgs
muSgs, alphaSgs, and k in running LES using rhoReactingBuoyantFoam DominicTNC OpenFOAM Running, Solving & CFD 2 May 22, 2017 04:35
