May 16, 2021, 05:45 |
Mass Addition on the Boundary Patch
Niyas
Rep Power: 13 |
Hi Foamers,
I have a simple rectangular geometry with inlet (left patch), outlet (right patch), symmetry (bottom patch) and wall (top patch). Please see the attached figure. On the wall (top patch), I need to add MASS ADDITION when the inside chamber temperature reaches certain value. How can I do that ?
Regards, Niyas |
May 16, 2021, 06:08 |
Herpes Free Engineer
Rep Power: 13 |
May be you can use flowRateInletVelocity boundary condition with the massFlowRate option? Or do you want to inject particles with certain mass flow rate into the domain?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 18, 2021, 04:41 |
Niyas
Rep Power: 13 |
Hi HPE,
Thanks for your reply. Yes, actually I want to inject particles with certain mass flow rate into the domain. Injection particle in my case is a solid propellant which burns and add to the flow.
Regards, Niyas |
May 18, 2021, 09:21 |
Rep Power: 13 |
Please see this tutorial then:
lagrangian/reactingParcelFoam/verticalChannelLTS and inspect its constant/reactingCloud1Properties for injectionModels section wherein parcels are added by using a specified mass flow rate.
May 21, 2021, 09:16 |
Niyas
Rep Power: 13 |
Thank you HPE.
I will look into it and post here if I have any further questions.
Regards, Niyas |
mass addition, openfoam |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
