OpenFoam, snappyHexMesh and Salome for patches "top, bottom wall'
Old   May 6, 2021, 16:26
Default OpenFoam, snappyHexMesh and Salome for patches "top, bottom wall'
Alberto Campuzano
baezacaljo is on a distinguished road
Hello dear all.
i am currently using openFoam and SnappyHexMesh. However nowadays i need to get involved with Salome in order to create my geometry.
i am practicing with the most simple geometry, a Box with an sphere inside of the Box.
Look after creating my stl files "top, bottom, wall" and riceHusk for the "sphere" and sending them into snappyHexMesh everything goes fine until i apply the solver (solids4Foam). My residuals are not converging at all, instead they are increasing.
So according to that i took the geometry from Tobias Holzmann from his webstie
HTML Code:
https://holzmann-cfd.com/community/training-cases/sphere-meshing
so i use his geometry created in salome and my results converged. it means that the solvers is not an issue
the issue comes from snappy or salome, let me mention that also i copied the snappyHexMesh from tobias from the link above and added faceZone, cellZone and cellZoneInside because i need to specify that some part of my geometry contains other parameters. And again using the geometry created by tobias (the same as mine) the system runs smooth and converge quite well
    refinementSurfaces
        polyester.stl
            // Surface-wise min and max refinement level
            level (0 0);
            regions
                bottom       { level (1 1); patchInfo { type patch; }}
                top      { level (1 1); patchInfo { type patch; }}
                wall        { level (1 1); patchInfo { type patch; }}
        riceHusk
            level (2 2);
            faceZone    faceZoneRiceHusk;
            cellZone    riceHusk;
            cellZoneInside inside;
//            boundary    internal;
With that being said i dont know why when i create my geometry (the same as tobias) the system does not converge?
the problems comes from snappyHexMesh or salome
any suggestions?
again, i am quite new to Salome. i dont know if this post must be in Salome.
in attached file you will find my geometry also the snappyHexMesh. i can not attach the geometry by tobias because of the file size. but the geometry can be found in the link mentioned above
thanks in advance
Alberto
geometryAndSnappy.zip
baezacaljo is offline   Reply With Quote
openfoam, salome, snappyhexmesh
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
OpenFoam and salome training on 2nd July at Pune, India sachinlb OpenFOAM Announcements from Other Sources 0 May 21, 2018 05:33
[CAD formats] How to scale the stl when importing from salome or any cad tool to openfoam vishalsharma OpenFOAM Meshing & Mesh Conversion 3 February 2, 2018 05:20
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 20:20
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
