Problem in using chtMultiRegionFoam for steady-state
Old   May 3, 2021, 13:09
Default Problem in using chtMultiRegionFoam for steady-state
mep
Muhammed Emin POLAT
mep is on a distinguished road
Hello all,
A physical problem occurs when I am configuring chtMultiRegionFoam as steady-state. Previous releases of OpenFOAM had included chtMultiRegionSimpleFoam for steady problems before OpenFOAM foundation merged transient and steady solver.
My problem is that even if it is not a transient case, the behaviour of my model is quite similar to transient due to higher diffusion number. I have three bodies where one of them is placed for conduction and other two are for both convection and conduction. Because of the relatively larger volume of region for conduction heat tranfer, convergence delays enormously.
The question, therefore, is about whether I can modify this problem so that it satisfies a quick convergence? Else, is it possible to integrate chtMultiRegionSimpleFoam in OF v8?
Thanks a lot for your replies.
mep is offline   Reply With Quote
Old   May 4, 2021, 06:59
Zeppo's Avatar
Sergei
Zeppo will become famous soon enough
Very slow convergence might be attributed to the fact that cht solver in question can only solve multiregion problems in segregated way, region by region, which makes solving a problem with lots of regions very annoying. Steady version will not resolve your issue.
Zeppo is offline   Reply With Quote
Old   May 6, 2021, 11:36
mep
Muhammed Emin POLAT
Thank you for your reply, Zeppo. Then, my question is to be evolved. I would like to set Pseudo transient approach to reach steady-state condition faster. I have attempted many times but have not accomplished yet. Is it not embedded in chtMultiRegionFoam solver in OF?
Old   May 6, 2021, 15:23
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Just for this reason there is possibility to add additional cycles for the temperature equation. Can't remember exactly, but I think it went into the 1706 or 1712 release.
olesen is offline   Reply With Quote
Old   May 16, 2021, 11:42
Zeppo's Avatar
Sergei
Alternatively, you can go for foam-extend version which offers coupled solver.
OpenFOAM 6, chtMultiRegionFoam residualcontrol for steady state not working qtruong OpenFOAM Running, Solving & CFD 10 December 18, 2019 03:24
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Problem with pimpleDyMFoam: Initialise steady state solution Lancester OpenFOAM Running, Solving & CFD 2 September 29, 2015 10:49
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 10:50
convergence problem in 3D steady state, laminar flow in a bath vajiheh FLUENT 0 July 10, 2009 13:18
