Floating point exception for pimpleFoam - FSI
Old   April 27, 2021, 14:59
Post Floating point exception for pimpleFoam - FSI
Ashish
ashishdarekar14 is on a distinguished road
Hello Members
I am solving Partitioned-FSI problem using two solvers: OpenFOAM (to solve the Fluid part) and Kratos solver (to solve the Structural part) and CoSimulation (Coupling solver to communicate between them)
OpenFOAM: I have selected the PIMPLE solver to solve std. benchmark problem of cylindrical flap (photo attached).
I am getting following error message after 2 time iterations:
with GAMG Solver
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#8 Foam::fvMatrix<double>::solve() in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#9 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
Floating point exception (core dumped)
with PCG Solver
#3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#5 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
#6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
Could anyone help me to understand these errors?? and how to approach this problem?
I have attached herewith
1. Problem diagram
2. Output of Meshcheck
3. FvSolution, ControlDict, etc..
Thanks in advance
File Type: txt fvSchemes.txt (819 Bytes, 2 views)
ashishdarekar14 is offline   Reply With Quote
Old   May 19, 2021, 02:21
Ashish
Hello all
So, I was able to advance some time steps in this problem.
I will provide more information about my problem.
1. I am solving a simple FSI-benchmarking case from Wall and Ramm (Attached herewith the test case). If you want more details about how I am solving kindly let me know
2. But simply, from OF side -> I am solving this problem using PIMPLE solver (controlDict, FvScheme, FvSolution files are attached herewith)
3. Dynamic Mesh is used for the motion of a flap (dynamicMeshDict also Attached)
4. Mesh: created using the BlockMesh (attached herewith the output of the checkMesh
-> initial and last time step, Last time step is failed due to non orthogonal mesh elements)
5. Also the Simulation stopped after few time steps: with the FPE (shown below)
Time = 0.0805
PIMPLE: Iteration 1
smoothSolver:  Solving for cellDisplacementx, Initial residual = 0.0509482779987, Final residual = 5.0820900698e-06, No Iterations 73
smoothSolver:  Solving for cellDisplacementy, Initial residual = 0.179955306297, Final residual = 1.78276847317e-05, No Iterations 61
GAMG:  Solving for pcorr, Initial residual = 1, Final residual = 8.99785732436e-05, No Iterations 26
GAMG:  Solving for pcorr, Initial residual = 0.333399937369, Final residual = 5.93490175136e-06, No Iterations 25
time step continuity errors : sum local = 4.24894215131e-08, global = -2.10306284577e-10, cumulative = -3.20959092079e-09
smoothSolver:  Solving for Ux, Initial residual = 0.116746487056, Final residual = 7.41363983302e-06, No Iterations 19
smoothSolver:  Solving for Uy, Initial residual = 0.0796490045324, Final residual = 4.92202324779e-06, No Iterations 20
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
6. Residuals plotted using residual function object. No more fluctuations (they are gone) but still the solution is not converging (attached herewith the latest graph).
So, Could anyone help me to understand the exact problem and how to tackle that? Any suggestion will be appreciated
If you want anything more about my case kindly let me know, I will provide it
Thanks in advance
Ashish
fsi, openfoam, pimplefoam
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
A floating point exception - SEM Model yansheng STAR-CCM+ 1 April 4, 2016 05:57
Floating point exception from twoPhaseEulerFoam openfoammaofnepo OpenFOAM Running, Solving & CFD 1 March 19, 2016 14:56
FATAL: floating point exception (AMG divergence) KeganLeckness FLUENT 1 December 2, 2015 12:10
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
