Modelling a thermal jet
Old   April 21, 2021, 07:27
Unhappy Modelling a thermal jet
Rebeca is on a distinguished road
Hi everyone!
I'm trying to calculate the 3D field of temperatures of a jet in OpenFoam, with no success. I'm new in OpenFoam and I don't really know neither which "case" I have to use inside of the "heatTransfer" folder, neither the exact boundary conditions I have to impose.
I hope you can help me!
Thank you in advance.
Rebeca
Rebeca is offline   Reply With Quote
Old   April 21, 2021, 07:35
Default Air flow
Hi again!
I forgot to say that my problem is a discharge of an engine's air (hot) into the onflow, which is also air but cooler and slower.
Thanks again!
Old   April 21, 2021, 09:29
Laika is on a distinguished road
I suggest to have a close look at the injectorPipe (rhoSimpleFoam) tutorial-case.
happy modeling,
Laika,
still orbiting
Laika is offline   Reply With Quote
Old   April 21, 2021, 09:32
Smile Compressible flow
Thank you so much for your response! I would try
Old   April 22, 2021, 04:58
Hi again! Do you know if there is any tutorial or website where I can see how to use the injectorPipe? I'm having troubles on extrapolating the case to my problem, and on watching the results.
Thanks in advance!
Old   April 22, 2021, 05:42
Default thermal jet
Hey Rebeca,
difficult to set you on the right track...
Where are you in terms of geometry and mesh? Which meshing tools are you using. What results are you looking for? Is your final goal a transient simulation, or a stationary simulation?
I recently did quite a lot of work with gas mixing with widely ranging temperatures with this solver, so it's all still very fresh in my mind...
best regards,
Laika,
still orbiting
laika@inorbit.eu
boundary conditions, jet, openfoam, temperature
Trouble modelling a jet fan josee OpenFOAM Pre-Processing 0 September 23, 2016 14:06
Using CFX for solid thermal analysis (no flow modelling) Maksim1990 CFX 1 December 6, 2014 04:52
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Modelling Jet Flow in a current Adrian FLUENT 3 January 12, 2006 11:42
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
