Convert denseParticleFoam to a conserved solver
Old   April 8, 2021, 12:15
Default Convert denseParticleFoam to a conserved solver
Mingze Gao
mgao1 is on a distinguished road
Hi there,
I am recently modifying the denseParticleFoam (DPFoam) and I want to convert it to a conserved solver.
The original code is:
1 fvVectorMatrix UcEqn
2 (
3 fvm::ddt(alphac, Uc) + fvm::div(alphaPhic, Uc)
4 - fvm::Sp(fvc::ddt(alphac) + fvc::div(alphaPhic), Uc)
5 + continuousPhaseTurbulence->divDevTau(Uc)
6 ==
7 (1.0/rhoc)*cloudSU
8 );
In my opinion, the 4th line will make the momentum equation a non-consered form. Therefore, when I modified the solver, I think I should remove this line, and the code will look like:
alphaRhoc = rhoc*alphac;
alphaRhocf = fvc::interpolate(alphaRhoc);
alphaRhoPhic = alphaRhocf*phic;
9 fvm::ddt(alphaRhoc, Uc) + fvm::div(alphaRhoPhic, Uc)
10 + turbulence->divDevTau(alphaRhoc,Uc)
11 ==
12 cloudSU
However, this will return me different results in all the fields (such as velocity, pressure, etc...) due to the 4th will not be a zero filed.
My question is, should I remove the 4th line of code to make it conserved form? If yes, is there any other code I should add to get a similar result?
Any help will be much appreciated!
Regards,
Mingze
mgao1 is offline   Reply With Quote
dense dpm, solver, solver modification
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
3d vof Smaras FLUENT 2 February 19, 2013 07:58
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
