Rigorous Second Derivative Zero - Boundary Condition
Old   March 26, 2021, 04:52
Default Rigorous Second Derivative Zero - Boundary Condition
samwong is on a distinguished road
Hi All,
I want to set the following condition for T for my problem.
i.e. some Flux due to Temperature and Pressure to be equal.
\frac{dT}{dx} + \frac{dP}{dx} = 0
I have tried to do this by calling lookupPatchField, then using Tp.snGrad().
Then I read Eugene's post for setting
\frac{d^2 T}{dx^2} = 0
by calling lookupObject then using fvc::grad.
I think the difference between fvc::grad and snGrad() is that,
fvc::grad use both internalField and patchField,
but snGrad() only use the patchField (boundary face and its cell's cell-center).
I wonder if using fvc::grad is better(more rigorous) then snGrad().
Eugene's post:
His code:
void extrapolatedGradientFvPatchScalarField::updateCoeffs()
    if (updated())
        return;
    word field = this->dimensionedInternalField().name();
    vectorField nf = patch().nf();
    volVectorField gradField
        = fvc::grad(db().lookupObject<volScalarField>(field));
    gradient()
        = (nf & gradField.boundaryField()[patch().index()]
        .patchInternalField()());
    fixedGradientFvPatchScalarField::updateCoeffs();
Here is my code
void equalGradientFvPatchScalarField::updateCoeffs()
    if (updated())
        return;
    const fvPatchField<scalar>& Pp =
           patch().lookupPatchField<volScalarField, scalar>(PName_);
    gradient() =  - Pp.snGrad();
Thanks,
Sam
samwong is offline   Reply With Quote
boundaries condition, openfoam, user defined boundary
Fatal overflow in linear solver. iamnotfajar CFX 9 October 28, 2020 05:47
Constant mass flow rate boundary condition sahm OpenFOAM 0 June 20, 2018 23:45
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
External Radiation Boundary Condition for Grid Interface CFD XUE FLUENT 0 July 9, 2010 03:53
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
