March 25, 2021, 03:47 |
limit diameter of parcels in sprayFoam
Riddhideep Biswas
Rep Power: 6 |
Hello everyone. I am trying to simulate a case using sprayFoam of OpenFOAM, where I am truing to limit the diameter of the injected parcels to a critical diameter. For example, if I inject parcels of diameter 4e-05, and if the heat transfer and phase change models are activated in the sprayCloudProperties dictionery, then the diameter of the parcels will gradually decrease and after some time become equal to 2e-05. After this, I want the diameter to remain constant at 2e-05 and don't want it to reduce further. How can I implement this above mentioned concept?
According to my knowledge, I know that size of a parcel decreases only due to heat transfer and evaporation (if we neglect breakup and collision models). So if I don't want diameter of parcels to decrease below 2e-05, I will have to switch off the heat transfer and evaporation models for those individual parcels which have reached 2e-05 size. How can I do this? |
parcel size, phasechange, sprayfoam |
sprayCloudProperties sprayFoam Lower Temperature limit | Lehaibmo | OpenFOAM Pre-Processing | 0 | November 8, 2020 11:27 |
Parcels injection with sprayFoam | Cluap | OpenFOAM Running, Solving & CFD | 3 | February 15, 2016 07:36 |
sprayFoam can not work when inject large diameter particle | xuebao123 | OpenFOAM Running, Solving & CFD | 0 | June 17, 2015 05:04 |
Unfinished particle tracks in simpleReactingParcelFoam | Cornelia | OpenFOAM Running, Solving & CFD | 3 | June 5, 2015 03:58 |
sprayFoam crashes | lukasfischer | OpenFOAM Running, Solving & CFD | 3 | July 14, 2013 11:08 |
