Write a calculated variable to postProcessing
Like Tree1Likes
Old   March 18, 2021, 11:38
Default Write a calculated variable to postProcessing
Vitor Monteiro
Vitor Monteiro is on a distinguished road
Hello, friends!
I'm trying to analyze the total mass of each component of my multi phase (fluidized bed pirolysis) simulations due time.
The total mass is calculated by the integration of (alphaGas*rhoGas) through volumes.
I've been trying it adding a controlDict coded function.
I've tried to use the simple calculations but I could have not write it to a file to plot data. Like this, mGas.write() doesn't work:
totalMass
    type            coded;
    libs            ("libutilityFunctionObjects.so");
    name            totalMass;
    writeControl    timeStep;
    codeWrite
        const volScalarField& alphaGas = mesh().lookupObject<volScalarField>("alpha.gas");
        const volScalarField& rhoGas = mesh().lookupObject<volScalarField>("thermo:rho.gas");
        const scalarField& v = mesh().V();
        const double& mGas = gSum(alphaGas*rhoGas*v);
        Info<< "coded totalMass output:" << endl
            << "    volIntegrate(all) for alpha.gas*rho.gas = "      << mGas << endl
            << endl;
        mGas.write();
Then i've tried to write the new variable as a field. This way I can write it but gSum integration didn't work.
totalMass
    type            coded;
    name            totalMass;
    codeWrite
            << "    volIntegrate(all) for alpha.gas*rho.gas = "      << gSum(alphaGas*rhoGas*v) << endl
            << endl;
        volScalarField mGas
                IOobject
                    "mGas",
                    mesh().time().timeName(),
                    mesh(),
                    IOobject::NO_READ,
                    IOobject::AUTO_WRITE
        mGas.write();
Vitor Monteiro is offline   Reply With Quote
Old   March 18, 2021, 15:25
Michael Alletto
mAlletto will become famous soon enough
Did you try to write your scalar to a file
mAlletto is offline   Reply With Quote
Old   March 18, 2021, 15:30
Vitor Monteiro
I thought the first implementation of mGas.write() would do this. But not.
How could I write to a file?
Sorry, I'm begginer to OF.
ERROR OF THE FIRST CODE ABOVE:
/home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/system/controlDict/functions/totalMass: In member function ‘virtual bool Foam::totalMassFunctionObject::write()’:
/home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/system/controlDict/functions/totalMass:128:10: error: request for member ‘write’ in ‘mGas’, which is of non-class type ‘const double’
/opt/openfoam8/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/functionObjectTemplate.o' failed
make: *** [Make/linux64GccDPInt32Opt/functionObjectTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/totalMass/platforms/linux64GccDPInt32Opt/lib/libtotalMass_048a1bfbed8a92a0b430065db7859e48d887c5b6.so"
file: /home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/system/controlDict/functions/totalMass from line 48 to line 60.
    From function void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const
    in file db/dynamicLibrary/codedBase/codedBase.C at line 206.
Inconsistency detected by ld.so: dl-close.c: 811: _dl_close: Assertion `map->l_init_called' failed!
ERROR OF THE SECOND ONE
/home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/system/controlDict/functions/totalMass:123:13: error: no matching function for call to ‘Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject, double)’
In file included from /opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.H:717:0,
                 from /opt/openfoam8/src/OpenFOAM/lnInclude/GeometricScalarField.H:38,
                 from /opt/openfoam8/src/OpenFOAM/lnInclude/GeometricFields.H:34,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/volFields.H:37,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/surfaceInterpolationScheme.C:27,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/surfaceInterpolationScheme.H:308,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/surfaceInterpolate.H:41,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/fvc.H:39,
                 from /opt/openfoam8/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from functionObjectTemplate.C:26:
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:697:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&, const wordList&, const wordList&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:697:1: note:   candidate expects 4 arguments, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:655:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const wordList&, const wordList&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:655:1: note:   candidate expects 4 arguments, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:621:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&, const Foam::word&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:621:1: note:   candidate expects 3 arguments, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:592:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:592:1: note:   no known conversion for argument 1 from ‘Foam::IOobject’ to ‘const Foam::word&’
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:561:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::word&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:561:1: note:   no known conversion for argument 1 from ‘Foam::IOobject’ to ‘const Foam::word&’
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:530:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:530:1: note:   no known conversion for argument 2 from ‘double’ to ‘const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >&’
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:499:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:499:1: note:   no known conversion for argument 2 from ‘double’ to ‘const Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&’
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:471:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::tmp<Foam::GeometricField<Type, PatchField, GeoMesh> >&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:471:1: note:   candidate expects 1 argument, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:443:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(Foam::GeometricField<Type, PatchField, GeoMesh>&&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:443:1: note:   candidate expects 1 argument, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:413:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::GeometricField<Type, PatchField, GeoMesh>&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:413:1: note:   candidate expects 1 argument, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:378:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:378:1: note:   candidate expects 3 arguments, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:343:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:343:1: note:   no known conversion for argument 2 from ‘double’ to ‘const Mesh& {aka const Foam::fvMesh&}’
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:317:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const Foam::Field<Type>&, const Foam::PtrList<PatchField<Type> >&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:317:1: note:   candidate expects 5 arguments, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:293:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Internal&, const Foam::PtrList<PatchField<Type> >&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Internal = Foam::DimensionedField<double, Foam::volMesh>]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:293:1: note:   candidate expects 3 arguments, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:266:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensioned<Type>&, const wordList&, const wordList&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh; Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:266:1: note:   candidate expects 5 arguments, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:240:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensioned<Type>&, const Foam::word&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:240:1: note:   candidate expects 4 arguments, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:215:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const wordList&, const wordList&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh; Foam::wordList = Foam::List<Foam::word>]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:215:1: note:   candidate expects 5 arguments, 2 provided
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:191:1: note: candidate: Foam::GeometricField<Type, PatchField, GeoMesh>::GeometricField(const Foam::IOobject&, const Mesh&, const Foam::dimensionSet&, const Foam::word&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh; Foam::GeometricField<Type, PatchField, GeoMesh>::Mesh = Foam::fvMesh]
/opt/openfoam8/src/OpenFOAM/lnInclude/GeometricField.C:191:1: note:   candidate expects 4 arguments, 2 provided
Failed wmake "dynamicCode/totalMass/platforms/linux64GccDPInt32Opt/lib/libtotalMass_8c0abe8d276be6bf178da552b57d5183bd8d3f7e.so"
Old   March 18, 2021, 15:38
Michael Alletto
There are a lot of threads here discussing how to write to a ASCII file. A few minutes googling openfoam write to ASCII will find a lot of pages.
Old   March 19, 2021, 09:11
hxaxtma is on a distinguished road
if (Pstream::master())
    std::ofstream fs;
    fs.open ("./postProcessing/stats_blablabla.dat", std::fstream::app);
    fs.precision(12);
    fs << mesh.time().value() << "\t" << V_ << "\t" << rho_ << "\t" << p_ << "\t" << T_<< "\t" << "\n";
    fs.close();
hxaxtma is offline   Reply With Quote
Old   March 20, 2021, 09:06
Michael Alletto
This piece of code is working for me. What this coded function object does is to calculate the center of mass of a bubble in each time step and write it to a file:
    centerOfGravityAir
        type coded;
        // Name of on-the-fly generated functionObject
        name writeCenterOfGravityAir;
        executeControl timeStep;
        codeOptions
            -I$(LIB_SRC)/finiteVolume/lnInclude \
            -I$(LIB_SRC)/OpenFOAM/lnInclude
        codeInclude
            #include "volFieldsFwd.H"
            #include "OFstream.H"
        codeData
              autoPtr<OFstream> outputFilePtr;
        codeRead
             outputFilePtr.reset(new OFstream("centerOfGravityAir.dat"));
        codeExecute
             const volScalarField& alpha1 = mesh().lookupObject<volScalarField>("alpha.water");
             scalar alphaTot (0.0);
             scalar cOG (0.0);
             forAll(alpha1,cellI)
                 alphaTot += 1.0 - alpha1[cellI];
                 cOG += (1.0 - alpha1[cellI])*alpha1.mesh().C()[cellI].z();
             reduce(alphaTot, sumOp<scalar>());
             reduce(cOG, sumOp<scalar>());
             cOG /= (alphaTot + VSMALL);
             if (Pstream::myProcNo() == 0)
                 outputFilePtr() << mesh().time().timeName() << " " << cOG << endl;
             Info << "cog = "  << mesh().time().timeName() << " " << cOG << endl;
        codeWrite
randolph likes this.
Old   March 20, 2021, 11:38
Vitor Monteiro
Thank you so much!
It helps a lot. Actually, I was testing this volume integration at the multiphaseEulerFoam tutorial (bubbleColumnEvaporating). Now I can go on my research.
This was the coded function object that worked for me:
totalMass
    type            coded;
    name            totalMass;
    writeControl    writeTime;//timeStep;
    executeControl    writeTime;
        codeInclude
        codeData
        codeRead
         outputFilePtr.reset(new OFstream("totalMass.dat"));
         outputFilePtr() <<   "# Time    gSum(alphaGas*rhoGas*v)    gSum(alphaGas)"   << endl;
    codeExecute
            << gSum(alphaGas*rhoGas*v) << "    "
            << gSum(alphaGas)  << endl;
I couldn't able to integrate using IOobject, don't know what was doing wrong. But this way is simpler and functionable.
Thank you so much!
Old   March 24, 2021, 13:34
Vitor Monteiro
Originally Posted by Vitor Monteiro View Post
totalMass
    type            coded;
    name            totalMass;
        codeInclude
        codeData
        codeRead
    codeExecute
How can I enable the phaseSystem functions into my coded function object, to gather informations about each phase.
I'd tried to simply use #include phaseSystem.H but it didn't work. I want to use functions like this:
autoPtr<phaseSystem> fluidPtr
    phaseSystem::New(mesh)
phaseSystem& fluid = fluidPtr();
phaseSystem::phaseModelList& phases = fluid.phases();
phaseModel& phase1 = fluid.multiComponentPhases()[0];
phaseModel& phase2 = fluid.multiComponentPhases()[1];
UPtrList<volScalarField>& Y2 = phase2.YActiveRef();
forAll(fluid.multiComponentPhases(), multiComponentPhasei)
        phaseModel& phase = fluid.multiComponentPhases()[multiComponentPhasei];
        UPtrList<volScalarField>& Y = phase.YActiveRef();
        const volScalarField& alpha = phase;
        const volScalarField& rho = phase.rho();
        forAll(Y, i)
Someone knows?
Old   March 24, 2021, 14:19
Michael Alletto
Did you try:
codeOptions
             -I$(LIB_SRC)/phaseSystemModels/multiphaseInter/phasesSystem/lnInclude/
Old   March 24, 2021, 14:38
Vitor Monteiro
Did you try:
codeOptions
Yes. I forgot to say that. It didn't work.
Actually, I also tried this, since I'm using OpenFOAM 8:
        codeOptions
-I/opt/openfoam8/applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/lnInclude
-I$(LIB_SRC)/thermophysicalModels/basic/lnInclude
My coded function object is been constructed like this:
totalMass
    type            coded;
    name            totalMass;
    executeControl    timeStep;//writeTime;
        codeInclude
        codeOptions
    codeLibs
        codeData
#include "phaseSystem.H"
        codeRead
         fileName outputDir = "./postProcessing/totalMass/" + mesh().time().timeName();
         mkDir(outputDir);
             outputFilePtr.reset(new OFstream(outputDir/"totalMass.dat"));
    codeWrite
    codeExecute
      forAll(fluid.multiComponentPhases(), multiComponentPhasei) // fases
        forAll(Y, i) // espécies
        phaseModel& phasei = Y[i].name();
        //phaseModel& phase1 = fluid.multiComponentPhases()[0];
            << gSum(alpha*rho*v) << "    "
            << gSum(alpha)  << endl;
            << "    volIntegrate(all) for alpha.gas*rho.gas = "      << alpha << endl
            << endl;
     }; // fim for
       }; //fim for
    #}; // fim Execute
 } // fim coded
Error obtained:
Using dynamicCode for functionObject totalMass at line 60 in "/home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/system/controlDict/functions/totalMass"
Creating new library in "dynamicCode/totalMass/platforms/linux64GccDPInt32Opt/lib/libtotalMass_326dfb08bc2c83669ba89b736cb4c23055d73758.so"
Invoking "wmake -s libso /home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/dynamicCode/totalMass"
wmake libso /home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/dynamicCode/totalMass
Make/linux64GccDPInt32Opt/options:66: *** missing separator.  Pare.
wmake error: file 'Make/linux64GccDPInt32Opt/sourceFiles' could not be created in /home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/dynamicCode/totalMass
Failed wmake "dynamicCode/totalMass/platforms/linux64GccDPInt32Opt/lib/libtotalMass_326dfb08bc2c83669ba89b736cb4c23055d73758.so"
file: /home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/system/controlDict/functions/totalMass from line 60 to line 109.
Old   March 24, 2021, 14:53
Michael Alletto
Did you try to put the #include statement in codeInclude?
Old   March 24, 2021, 14:55
Vitor Monteiro
Yes. Then I've got this:
Creating new library in "dynamicCode/totalMass/platforms/linux64GccDPInt32Opt/lib/libtotalMass_0bbae05ec8449bd9ed9eae095bd5ddc094e82abe.so"
Make/linux64GccDPInt32Opt/options:60: *** missing separator.  Pare.
Failed wmake "dynamicCode/totalMass/platforms/linux64GccDPInt32Opt/lib/libtotalMass_0bbae05ec8449bd9ed9eae095bd5ddc094e82abe.so"
file: /home/vitor/SIMULATIONS/tutorials8/multiphase/multiphaseEulerFoam/laminar/bubbleColumnEvaporating/system/controlDict/functions/totalMass from line 60 to line 110.
Old   March 24, 2021, 15:00
Michael Alletto
You need a back slash between the two lines in codeOption
See the working example I sent
Old   March 24, 2021, 15:01
Vitor Monteiro
It seems like it worked:
totalMass
    type            coded;
    name            totalMass;
        codeInclude
        codeOptions
-I/opt/openfoam8/applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/lnInclude \
    codeLibs
        codeData
          autoPtr<phaseSystem> fluidPtr;
        codeRead
         mkDir(outputDir);
    codeWrite
    codeExecute
     const double& m = gSum(alpha*rho*v);
            << Y[i].name() << "    "
            << m  << endl;
            << "    name: " << Y[i].name() << endl
        << "    mass: " << m << endl
            << endl;
     }; // fim for
       }; //fim for
    #}; // fim Execute
} // fim coded
However, now it seems like something is missing:
object of type N4Foam11phaseSystemE is not allocated
    From function T& Foam::autoPtr<T>::operator()() [with T = Foam::phaseSystem]
    in file /opt/openfoam8/src/OpenFOAM/lnInclude/autoPtrI.H at line 139.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::totalMassFunctionObject::execute() at /opt/openfoam8/src/OpenFOAM/lnInclude/errorManip.H:84
#3  Foam::functionObjects::timeControl::execute() at ??:?
#4  Foam::functionObjectList::start() at ??:?
#5  Foam::Time::run() const at ??:?
#6  ? at ??:?
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8  ? at ??:?
Aborted (core dumped)
Old   March 25, 2021, 13:02
Vitor Monteiro
Same error occurred (see above, I edited my reply):
Old   March 26, 2021, 05:54
Michael Alletto
can you try something like this in codeExecute
const phaseSystem& fluid = mesh().lookupObject<phaseSystem>
and remove
Since your phaesSystem object already exists you do not need to create it but just retrieve it from the datebase
Old   March 26, 2021, 13:26
Vitor Monteiro
: error: invalid initialization of reference of type ‘const Foam::phaseSystem&’ from expression of type ‘<unresolved overloaded function type>’
I've got another error. Do you know what is happening?
The curious thing is that I can use this functions properly at my edited solver of multiphaseEulerFoam.C or YEqns.H but, in the coded function object inside controlDict it doesn't work.
Maybe its some other library I have to activate? Or something like that?
This is the working code implemented at YEqns.H, for example:
        forAll(Y, i)
Old   March 26, 2021, 15:35
Michael Alletto
It is clear that the object you are looking for is visible in the main solver. It is created in the createField.H file. This is the outermost scope.
A coded function objects does not know anything about the application. If you want an object there which is used from the main application you have to retrieve it from the database
Old   March 29, 2021, 12:10
Thumbs up
  #19
Vitor Monteiro
That's true. I understood that. Since I wasn't knowing how to retrieve that information, I've prefered to implement that calculus and write it to a file inside the main solver. So I edit and compiled that. This way I could solve the problema.
Thank you very much for help.
Old   March 29, 2021, 12:25
Michael Alletto
Can you post the code? Maybe it's of help for someone else
coded functions, gsum(), integration, postprocessing, write to file
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Condensation as an additional variable Clark Griswold CFX 2 April 21, 2012 08:20
Additional variable as output of an expression Chander CFX 1 November 22, 2011 13:54
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
