chtMultipleRegionFoam: quenching, temperature problem |
March 17, 2021, 18:30 |
Rep Power: 5 |
Hello everyone ,
I have to modelise a quenching of a block ( at 1000 °C) in a chamber at the same temperature with a gas (air for now) injected a 20°C and a velocity of 10 m/s (through the tubes). The outlet is the dark blue circle at the back. furnace.jpeg All the time the simulation crashes after a few iterations due to either a temperature explosion or negative temperatures. I have tried to refine the mesh, change some boundary conditions, lower the relaxation factors... Unfortunately, I always crashed for min/max T that diverged Here is the error left by the log file: log.txt All my schemes are set to upwind ( except for K an the stress tensor which are set to linear) . I can't do more stable than that, the error should be in the boundary conditions . Below there are a few details of the conditions I am imposing: I really don't know what is wrong. I tried to change for the temperature multiple times the only time it did not crash was when I set an internalField of temperature at the same temperature as the inlet ( 293 K ) , but the results had no sens and it is not the situation I want to study. Can somebody give me some advice or how to do to solve that problem ? Or may be is there something else that the BCs that could be wrong in that kind of situation? Sorry for this long message but I wanted to set correctly my problem. Thank you in advance Details: For the fluid my change dictionary is Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object changeDictionaryDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // boundary { outlet { type patch; } "inlet.*" { type patch; } walls { type wall; } } U { internalField uniform (0 0 0); boundaryField { walls { type noSlip; } vaccum_to_block ///// -------------------- { type noSlip; } outlet { type zeroGradient; value uniform (0 0 0); } "inlet.*" // change here in case of problem { type codedFixedValue; value uniform (0 0 0); name inletNbc; code #{ // Patch is an object of class fvPatch const fvPatch& patch = this->patch(); // n stores all surface normal vectors const vectorField& n = patch.nf(); scalar Uinlet = 10; scalarField U (this->size(), Uinlet); operator==(U * n); #}; } "procBoundary.*" { type processor; } } } T { internalField uniform 1273; boundaryField { walls { type zeroGradient; value $internalField; } outlet { type zeroGradient; value $internalField; } "inlet.*" { type fixedValue; value uniform 293; // 20 deg } "procBoundary.*" { type processor; } "vaccum_to_.*" { type compressible::turbulentTemperatureCoupledBaffleMixed; // check incompressible // check : https://www.openfoam.com/documentation/guides/latest/api/classFoam_1_1temperatureCoupledBase.html Tnbr T; kappaMethod fluidThermo; value $internalField; } } } epsilon { // Set the value on all bc to non-zero. Not used in simulation // since zeroGradient; only used in initialisation. internalField uniform 0.01; boundaryField { walls { type epsilonWallFunction; //compressible::epsilonWallFunction; value uniform 0.01; } "vaccum_to_.*" { type epsilonWallFunction; value uniform 0.01; } "inlet.*" // ----------------------------------------------- check { type inletOutlet; inletValue $internalField; //turbulentMixingLengthDissipationRateInlet; //mixingLength 0.02; value $internalField; } outlet { type zeroGradient; } "procBoundary.*" { type processor; } } } k { internalField uniform 0.1; boundaryField { "inlet.*" { type inletOutlet; inletValue $internalField; // turbulentIntensityKineticEnergyInlet; //intensity 0.05; value $internalField; } outlet { type zeroGradient; } walls { type kqRWallFunction; value $internalField; } "vaccum_to_.*" { type kqRWallFunction; value $internalField; } "procBoundary.*" { type processor; } } } p_rgh { internalField uniform 5e5; boundaryField { walls // ------------------------ check for inlets { type fixedFluxPressure; // bc for walls value $internalField; // 1e5 pressure without static pressure } "inlet.*" // ------------------------ check for inlets : ok cht 33 { type fixedFluxPressure; // bc for walls value $internalField; // 1e5 pressure without static pressure } outlet { type zeroGradient; } vaccum_to_block // ------------------------ check for inlets { type fixedFluxPressure; // bc for walls value $internalField; // 1e5 pressure without static pressure } "procBoundary.*" { type processor; } } } p { internalField uniform 1e5; // 1 bar boundaryField { ".*" { type calculated; // zeroGradient value $internalField; } "procBoundary.*" { type processor; } } } // ************************************************************************* // the fluid's fvSolution Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "(rho|rhoFinal)" { solver PCG; preconditioner DIC; tolerance 1e-7; relTol 0; } p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother GaussSeidel; } p_rghFinal { $p_rgh; tolerance 1e-7; relTol 0; } "(U|h|k|epsilon|R)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-7; relTol 0.1; } "(U|h|k|epsilon|R)Final" { $U; tolerance 1e-07; relTol 0; } } PIMPLE { momentumPredictor yes; nCorrectors 1; nOuterCorrectors 100; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 1e5; outerCorrectorResidualControl // residualControl { p { tolerance 1e-4; relTol 0; } U { tolerance 1e-5; relTol 0; } h { tolerance 1e-4; relTol 0; } } } relaxationFactors { fields { p_rgh 0.3; } equations { "U.*" 0.7; "(k|epsilon)" 0.5; "(h|e)" 0.5; } } // ************************************************************************* // and the changeDirectory for the solid block Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object changeDictionaryDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // boundary { // As there is no boundary (inside the block) } T { internalField uniform 1273; boundaryField { "procBoundary.*" { type processor; } "block_to_.*" { type compressible::turbulentTemperatureCoupledBaffleMixed; Tnbr T; kappaMethod solidThermo; value uniform 1273; // 1000 deg } } } // ************************************************************************* // |
March 22, 2021, 00:23 |
W.T
Rep Power: 13 |
You can strictly bound temperature in the solver to the specified limits by using fvOption "limitTemperature"
https://www.openfoam.com/documentati...mperature.html |
March 23, 2021, 17:24 |
Rep Power: 5 |
Yes I applied this and I saw when I got the results that instead of injecting gas through the inlets, they were sucking the air from the chamber. So initially it was an error in the BCs. Now I don't need the limiter anymore.
Thank you very much ! |
[openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 09:21 |
Problem in temperature profiles while using rhoSimpleFoam for Nozzle case | Nik_04 | OpenFOAM Running, Solving & CFD | 0 | February 4, 2017 05:04 |
Problem with Turbulent Heat Flux Temperature boundary condition | Manuel CFD | OpenFOAM Running, Solving & CFD | 11 | March 17, 2016 15:12 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
