Rep Power: 5 ![]() |
Hello.
I'm trying to calculate the aerodynamic heating of a plane that is flying in a defined trayectory. Is it possible to use OpenFoam or with OpenFoam I will only obtain the temperature field of the fluid, not over the surface? Thank you in advance. |
Michael Alletto
Rep Power: 16 ![]() |
The temperature is defined also on the surfaces
Aerodynamic heating in SU2 | Rebeca | SU2 | 5 | March 12, 2021 15:01 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
Calculate aerodynamic coefficients with openfoam using only opensource programs | Xwang | OpenFOAM | 20 | May 20, 2016 11:26 |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 04:57 |
Aerodynamic Heating | J. Julia | Main CFD Forum | 1 | August 9, 1998 12:10 |
