i am trying to solve the sliding cover problem over a cavity with two fluids water an |
February 21, 2021, 15:25 |
pedro cornacini
========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0)//0 (0 0 1)//1 (0 0.5 1)//2 (0 0.5 0)//3 (1 0 0)//4 (1 0 1)//5 (1 0.5 1)//6 (1 0.5 0)//7 (0 0.5 0)//8 (0 0.5 1)//9 (0 1 1)//10 (0 1 0)//11 (1 0.5 0)//12 (1 0.5 1)//13 (1 1 1)//14 (1 1 0)//15 ); blocks ( hex ( 0 1 2 3 4 5 6 7) ( 200 200 1) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) ( 200 200 1) simpleGrading (1 1 1) ); edges ( ); boundary ( walls { type wall; faces ( (0 4 7 3)//1 (2 6 5 1)//2 (1 5 4 0)//3 (3 7 6 2)//4 (12 15 11 8)//5 (10 14 15 9)//6 (9 13 12 8)//7 (11 15 14 10)//8 ); } movingWall { type wall; faces ( (11 15 14 10) ); } fixedWalls { type wall; faces ( (0 4 7 3)//1 (2 6 5 1)//2 (1 5 4 0)//3 (3 7 6 2)//4 (12 15 11 8)//5 (10 14 15 9)//6 (9 13 12 8)//7 ); } frontBack { type empty; faces ( (0 3 2 1) (4 5 6 7) (3 11 10 2) (7 6 14 15) ); } ); // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object transportProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // mul [1 -1 -1 0 0] 0.0065; muv [1 -1 -1 0 0] 5.953e-06; phases ( water); water { transportModel Newtonian; nu [0 2 -1 0 0 0 0] 124.775; rho [1 -3 0 0 0 0 0] 998.2; } oil { transportModel Newtonian; nu [0 2 -1 0 0 0 0] 111.125; rho [1 -3 0 0 0 0 0] 889; } // ************************************************** *********************** // /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : dev-d35103fe2221 Exec : blockMesh Date : Feb 21 2021 Time : 16:11:47 Host : "pedro-H110M-H" PID : 15276 I/O : uncollated Case : /home/pedro/OpenFOAM/mistura/cavitatingFoam/LES/throttle nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks --> FOAM FATAL IO ERROR: Block hex (0 1 2 3 4 5 6 7) (200 200 200) simpleGrading (1(1) 1(1) 1(1)) is inside-out file: /home/pedro/OpenFOAM/mistura/cavitatingFoam/LES/throttle/system/blockMeshDict/blocks at line 46. From function void Foam::blockDescriptor::check(const Foam::Istream&) in file blockDescriptor/blockDescriptor.C at line 100. |
Coupled Heat and Mass Transfer | Mecroob | OpenFOAM Running, Solving & CFD | 1 | July 12, 2020 20:24 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 05:37 |
OpenFOAM v1912 Green Water Loading Case Implementation Problem | leuthar | OpenFOAM Running, Solving & CFD | 2 | March 12, 2020 17:42 |
Simulation Water and Oil URGENT problem | alexandrelp | CFX | 3 | May 5, 2014 22:20 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 10:11 |
