February 11, 2021, 12:49 |
Using icoFoam after snappyHexMesh
Abdullah Saifee
Rep Power: 5 |
I am trying to run icoFoam through a geometry made by Gmsh. For meshing, I have used snappyHexMesh. For that I had the geometry made with Gmsh by someone else and converted to a *.stl file.
The meshing seems fine when I see it in Paraview. But when I run icoFoam, all the diagnostics show zero (e.g. Courant numbers, all the residuals etc.). I was surfing to resolve the issue, that's when I found that it might be because in the *.stl file the regions aren't named as I have named them in the p and U files in the 0 folder. How to resolve this? I have attached some files here which I thought might be helpful to understand the problem. |
gmsh files, icofoam, openfoam, snapphhexmesh, snappy hex mesh |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
Strange Results With snappyHexMesh | calebamiles | OpenFOAM Running, Solving & CFD | 0 | August 14, 2011 16:02 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
