Compiler gcc/mpicc doesn't work anymore since OpenFoam is installed
Old   February 11, 2021, 03:24
Default Compiler gcc/mpicc doesn't work anymore since OpenFoam is installed
Thibaut
Taendyr is on a distinguished road
I installed OpenFoam on Windows like recommended here: https://openfoam.com/download/install-windows-10.php
I works perfectly, I can run my simulations without any problem.
The problem is when I wank to compile a C or C++ program I coded. When I try to compile it I have the message :
/opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/bin/../libexec/gcc/x86_64-pc-linux-gnu/6.3.0/cc1: error while loading shared libraries: libmpfr.so.4: cannot open shared object file: No such file or directory.
Since it is opt/OpenFOAM/, I guess that this comes from OpenFOAM.
When I do $which gcc, I have
/opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/bin/gcc.
How can I do ?
I already removed all the OpenFOAM files and reinstalled gcc, it worked perfectly. But this can not be a long term solution
Taendyr is offline   Reply With Quote
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
[OpenFOAM.com] OpenFoam installation failure with g++ internal compiler error WUYing OpenFOAM Installation 1 April 2, 2020 17:46
I need help using newly installed OpenFoam Package please? Estes OpenFOAM Installation 1 September 7, 2011 05:16
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 12:18
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
