Spalart-Allmaras turbulence model for turbulent flat plate tutorial |
February 6, 2021, 19:24 |
Bartolomeo Fanizza
Rep Power: 7 |
Hi everyone,
I'm recently getting deep with the OpenFOAM tutorial "turbulentFlatPlate". I successfully run the tutorial with the k-epsilon and the k-omega models (already implemented in the tutorial). After that i tried to change the turbulence model with the Spalart Allmaras model. Firstly i created the folder "0.SpalartAllmaras" with U, p, nut and nuTilda defined inside. Then i modified the fvSolution and fvSchemes and setted the Spalart Allmaras model in the "Allrun" script. When i run the simulation i get this error: Processing model: SpalartAllmarasI attach also the log.simpleFoam.SpalartAllmaras_5 file: Time = 1I don't know if i need to adjust something yet or if I'm taking a wrong method from the beginning. I really want to understand how to fix the problem and i would be glad if someone can help me (even a clear tutorial link can be helpfull) to understand how to implement a different turbulence model in a openfoam tutorial. I attach also the folder i prepared for the simulation in the zip format in case you need to take a look to others files. Thank you Regards Bartholomew Last edited by Bartholomew; February 7, 2021 at 16:46. |
flat plate, openfoam, ras, spalart allamaras, turbulence |
Spalart Allmaras Gamma Re Theta Model | taxalian | SU2 | 4 | December 14, 2020 05:45 |
Transition prediction and validation of flat plate using fluent transition SST model | Cambridge | FLUENT | 2 | June 20, 2020 06:08 |
Is Spalart Allmaras DES still the best turbulence model for external aero? | edomalley1 | Main CFD Forum | 4 | October 5, 2018 17:48 |
Supersonic flow over flat plate - best model | Chris Rand | FLUENT | 4 | October 3, 2000 07:58 |
Turbulence dead? well... can somebody help me with a flat plate meanwhile? | Javier | Main CFD Forum | 2 | May 23, 2000 05:41 |
