openfoam c mesh
Old   January 26, 2021, 13:41
Default openfoam c mesh
hiaselhans is on a distinguished road
Hi Foamers!
I need to make a good c-mesh simpleFoam case for airfoil drag validation.
After quite some time of parameter optimization, i think i need some help to get a decent solution. Most of the time i have around 100% overprediction on Cd.
My mesh consists of several boundary layers with grading (~1.05) and farfield layers with a different grading (~1.1). the mesh is also graded so that on the transition from airfoil trailing edge to the wake mesh there is no jump in cell-width.
I tried several approaches for the mesh (pictures attached)
  1. straight wake, boundary layer straight to the end
  2. straight wake but the boundary layer fades out towards a linear distribution at the end
  3. same as (1) but aligned with the flow (angle of attack)
  4. same as (2) but aligned with the flow
option 1 had the least overprediction after a lot of parameter-finding but that was not very reproducible. Varying the stream angle changed the result A LOT.
  • start_thickness: 0.0018
  • num_boundary': 10
  • num_farfield': 55
  • numpoints': 300
  • growth_rate': 1.14
  • growth_rate_boundary': 1.05
  • wake_length': 30
  • wake_num': 150
  • domain_height': 25.0
  • yplus_min: 11.0289
  • yplus_max: 62.8056
  • yplus_avg: 26.8322
From digging this forum i found some answers using an y+ ~ 1.
Is it really necessary to have such a dense mesh with the k-omega-sst (or spallart-almarras) turbulence model?
I'd really appreciate your opinions on the mesh types and parameters
Thanks!
Simon
hiaselhans is offline   Reply With Quote
Old   January 29, 2021, 18:14
Ran
random_ran is on a distinguished road
The meshes you show in Figs. 1~4 have very large aspect ratio.
You may try to increase the number of the mesh cells and keep the mesh more "square".
Yours in CFD,
Ran
random_ran is offline   Reply With Quote
Tool to convert OpenFoam mesh to SU2 mesh (2D and 3D) Combas SU2 45 October 16, 2024 18:26
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM nsf OpenFOAM Meshing & Mesh Conversion 86 February 8, 2023 11:30
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 03:54
