January 23, 2021, 05:29 |
Openfoam 5.x on Ubuntu 20
Anjul Pandey
Rep Power: 6 |
Hello everyone,
I am currently using OpenFOAM 5.x on Ubuntu 18.04. I have an upgrade option that will upgrade my system to Ubuntu 20.04. I want to upgrade but I am not sure whether my OpenFOAM will work fine or cause an error if I upgrade. PS: I had no idea where to post a question like this so I posted it here. Apologies if it off topic. |
February 1, 2021, 08:47 |
Tobias Holzmann
Rep Power: 52 |
Dear Anjul,
you can use Ubuntu 20 and OpenFOAM-5. However, depending on how you managed to run FOAM on you system, it might be broken. E.g., if you installed it using *.deb files. If you compiled the solvers yourself, there is no problem. However, keep in mind that OpenFOAM 5 is almost 3 versions behind the official release and a newer version includes bug-fixes and extensions.
Keep foaming, Tobias Holzmann |
Problem in transferring flameletFoam to OpenFOAM 5.x | anjul | OpenFOAM Community Contributions | 5 | February 8, 2021 00:32 |
[OpenFOAM.org] icoFoam: Command not found in OpenFOAM 3.0.1 installation on Ubuntu 16.10 | febriyan91 | OpenFOAM Installation | 2 | July 27, 2020 01:23 |
[OpenFOAM.org] Can't find installation instruction for Openfoam 2.4.x , on Ubuntu 16.04 | titanium | OpenFOAM Installation | 14 | February 20, 2020 12:46 |
[OpenFOAM.org] what happens for OpenFOAM related codes when upgrading ubuntu | babakflame | OpenFOAM Installation | 4 | December 31, 2014 10:40 |
How to Install OpenFOAM on 64 Ubuntu 9.04 | hansel | OpenFOAM Installation | 62 | March 19, 2010 15:43 |
