Naca0012 with rhoCentralFoam
Old   January 7, 2021, 11:32
Default Naca0012 with rhoCentralFoam
Thibaut
Taendyr is on a distinguished road
Hi, I'm trying to use rhoCentralFoam on the case aerofoilNACA0012 in order to compare the results with those obtained with sonicFoam.
Actually, I took the case from $FOAM_TUTORIALS/compressible/sonicFoam/RAS/aerofoilNACA0012. The application in ControlDict was rhoPimpleFoam. I changed it to sonicFoam. It worked.
I then changed to rhoCentralFoam, added what was asked in fvScheme and after a few iterations, I have a negative temperature.
As you could guess, I'm new to OpenFoam and I may not use the good way to work.
How can I use the case to compare both solver ?
It actually may not be exactly that case, I juste want a compressible turbulent case (the prism case gives me the same problem).
Thanks
Taendyr is offline   Reply With Quote
How to apply a turbulence model to the rhoCentralFoam solver? arussell92 OpenFOAM Pre-Processing 18 July 25, 2022 05:26
Modify rhoCentralFoam: other equations of state fivos OpenFOAM Programming & Development 5 July 29, 2020 14:17
NACA0012 with rhoCentralFoam praveen OpenFOAM 17 July 5, 2018 06:49
Inviscid simulation in rhoCentralFoam chencw OpenFOAM Running, Solving & CFD 0 April 13, 2018 16:49
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 09:00
