[QUESTION: Fully Developed Rectangle Channel Simulation]
Old   December 24, 2020, 09:46
Default [QUESTION: Fully Developed Rectangle Channel Simulation]
Anthony
Anthonyyy is on a distinguished road
Dear all:
Thanks for click this post. Recently I had some trouble with the simulation of fully-develped rectangle channel. The goal is to show the maximum velocity appears under the surface due to the effects of secondary flow. The surface velocity as init condition is distributed in a parabolic way as in fig [surfaceVelocityDistribution.jpg].
I try to solve this problem with simpleFoam but got something strange. The velocity profile vanish quickly in the first 0.2 m depth, as in fig [profile.jpg]
Here is my U file, the rest of my code could be check in [rectangleSimulation.zip]
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet
        //type            fixedValue;
        //value	        uniform (0 10 0);
        type		cyclic;
    outlet
        //neighbourPatch  outlet;
        //type            zeroGradient;
        type		cyclic;
    upperWall
        type            fixedValue;
        value           #codeStream
            codeInclude
                #include "fvCFD.H";
            codeOptions
                -I$(LIB_SRC)/finiteVolume/lnInclude \
                -I$(LIB_SRC)/meshTools/lnInclude
    	    //libs needed to visualize BC in paraview
    	    codeLibs
        	-lmeshTools \
        	-lfiniteVolume
            code
                const IOdictionary& d = static_cast<const IOdictionary&>
                    dict.parent().parent()
                const fvMesh& mesh = refCast<const fvMesh>(d.db());
                const label id = mesh.boundary().findPatchID("upperWall");
                const fvPatch& patch = mesh.boundary()[id];
                vectorField U(patch.size(), vector(0, 0, 0));
                forAll(U, i)
                    const scalar x = patch.Cf()[i][0];
                    U[i] = vector(0., -1*2*x*(x-4)-0.057, 0.);
                U.writeEntry("", os);
    lowerWall
        //type            noSlip;
	type		fixedValue;
	value	uniform (0 0 0);
    frontAndBack
        // type       noSlip;
	type		fixedValue;
I would appreciate it if someone can help me with this problem.
REFERENCE
[1]Shi, J., T. G. Thomas, and J. J. R. Williams. "Large-eddy simulation of flow in a rectangular open channel." Journal of Hydraulic Research 37, no. 3 (1999): 345-361.
[2]Kang, Hyeongsik, and Sung‐Uk Choi. "Reynolds stress modelling of rectangular open‐channel flow." International journal for numerical methods in fluids 51, no. 11 (2006): 1319-1334.
Anthonyyy is offline   Reply With Quote
Old   December 25, 2020, 10:27
Michael Alletto
mAlletto will become famous soon enough
did you try the apply cyclic boundary condition together with meanVelocityForce fvOption?
This gives you a volumetric source term to obtain a specified mean velocity. In this way you can fix the Reynoldsnumber based on the bulk velocity.
A tutorial can be found in incompressible/pimpleFoam/LES/channel395
What's the purpose to apply a parabolic profile at the top surface? The velocity at the upper wall should result from the solution
Best
Michael
mAlletto is offline   Reply With Quote
Old   December 25, 2020, 10:50
Anthony
Best
Michael
Dear Michael:
Thanks for your kindly reply. It is precisely where the problem happens. I had found some threads similar to your answer. I did not set the bulk velocity in the fvOption file.
The reason for setting the parabolic profile at the top surface is that I want to figure out what the velocity profile will be under the given surface velocity distribution(obtained by PIV, in the ideal case, it's parabolic), so I fix the upper boundary condition and run the k-omega model.
Best regards,
Anthony
Reference Threads:
- Periodic Boundary Condition
- Inlet conditions for cyclic problem
boundaryconditions, channel, cyclic, openfoam, simplefoam
Field function - Fully developed flow profile for a square micro channel smorls Main CFD Forum 5 April 9, 2015 12:01
UDF for 3D turbulent fully developed flow howhs Fluent UDF and Scheme Programming 0 August 1, 2013 12:47
How to introduce my desired fully developed Boundary Condition? Milad06 OpenFOAM Running, Solving & CFD 0 July 8, 2013 05:54
Fully developed flow ,CEL expression kmgraju CFX 0 August 6, 2010 05:15
Fully Developed Flow kpsudhakar CFX 4 June 7, 2010 07:03
