November 16, 2020, 15:28 |
BUG: decomposePar changing BCs
Rep Power: 8 |
I have noticed that decomposePar changes the boundary conditions, which is very annoying if you want to use many cores. For e.g. it changed: Code:
outlet { type waveTransmissive; field p; psi thermo:psi; fieldInf 101325; gamma 1.4; lInf 1; value uniform 101325; } Code:
outlet { type waveTransmissive; gamma 1; fieldInf 101325; lInf 1; value nonuniform 0(); } Can anyone tell me how to solve this problem? I use openfoam4.1. |
November 18, 2020, 17:32 |
Mark Olesen
Rep Power: 40 |
That is a fairly old version.
You need to see if this problem still exists in a newer version (eg OpenFOAM-v2006) if does then go to the issue tracker to describe the problem and provide a small test case. |
November 18, 2020, 18:16 |
Rep Power: 8 |
I am using the version of openfoam.org.
I have tried the same with openfoam 5 and openfoam7. The issue remains the same. |
November 23, 2020, 14:49 |
#4 | |
Mark Olesen
Rep Power: 40 |
Cheers |
November 24, 2020, 04:39 |
Rep Power: 8 |
Hi oelsen,
I reported the bug on https://bugs.openfoam.org/rules.php. As it seems the bug occurs only on my computer, what is really odd, since it occurs with different versions of openfoam. What also is important, is that you have to use 1.4 and not 7/5, because otherwise its not recognizes as 1.4. |
mapFields major bug | alchem | OpenFOAM Bugs | 14 | September 15, 2023 13:48 |
LEMOS-2.3.x inflow generator bug with decomposePar | chenyr10 | OpenFOAM Pre-Processing | 1 | November 21, 2017 13:31 |
Bug in Workbench CFX | Pierre1 | CFX | 6 | August 2, 2017 01:18 |
checkMesh and decomposePar crashes with salome IDEAS mesh | pajofego | OpenFOAM | 0 | June 23, 2011 09:43 |
Bug or a feature of OF15 | rafal | OpenFOAM Bugs | 5 | July 25, 2008 06:25 |
