Foam printstack error
Old   November 9, 2020, 07:38
Default Foam printstack error
Vlad
DrDerpy13 is on a distinguished road
Hello Guys,
I am struggling to simulate a duct flow for 2 days. I ve tried the following things:
1. i calculated the values for k and epsilon
2. i assured that the boundaries are good defined
3. i checked the mesh
After all the things from above done i can say that i have literally no clue what to do anymore
smoothSolver: Solving for Uz, Initial residual = 0.713672, Final residual = 0.0458908, No Iterations 20
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in /lib64/libpthread.so.0
#3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(F oam::dictionary const&) at ??:?
#8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:?
#9 ? at ??:?
#10 __libc_start_main at :?
#11 ? at ??:?
Many thanks in advance
DrDerpy13 is offline   Reply With Quote
Old   November 9, 2020, 10:09
oswald is on a distinguished road
I would assume, that you set something that leads to a division by zero, as indicated by sigFpe in error #1. But without any information about your setup, it's hard to say what is causing this.
oswald is offline   Reply With Quote
Old   November 10, 2020, 16:22
Ash Kotwal
Ash Kot is on a distinguished road
Originally Posted by DrDerpy13 View Post
Hello Guys,
Provide your residuals and boundary conditions in all files from 0 folder.
If the 'courant number' starts reducing after certain time, that means something is wrong with A] the boundary conditions or B] Mesh.
So run
 checkMesh -allTopology -allGeometry
command and post the output as well as the boundary conditions, that is files from 0 folder.
Ash Kot is offline   Reply With Quote
Old   January 11, 2021, 03:43
Vlad
sorry for coming back with a late answer. the reason of my error was the overlapping of volume mesh with my layers
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
