November 4, 2020, 16:02 |
Urban Flow
I'm a new user of openFOAM and I've run the windAroundBuilddings case and seen the following forums: Importing mesh files to OpenFOAM: is obj format viable? SnappyHexMeshing SnakeRiverCanyon tutorial terrain import openFoam How to simulate Urban Environment with buildings and trees in OpenFOAM and none of them gave me a concrete answer on how I can put my urban environment, .obj file on windAroundBuildings. Someone could help? |
November 10, 2020, 23:15 |
#2 | |
Rep Power: 16 |
At its simplest, you need to replace the file name in snappyHexMeshDict with the name of your OBJ file. You also need to ensure that the vertices in blockMeshDict, and the locationInMesh point in snappyHexMeshDict are in line for your case. Can you elaborate on what exactly you mean by Quote:
Cheers, Antimony |
November 12, 2020, 06:34 |
Thank u very much, that's exactly what i wanted to know... if doing just that was correct. Best |
flow, urban, windaroundbuildings |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Urban wind flow modelling - formular needed | charltonjames | Main CFD Forum | 0 | September 4, 2009 08:16 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 07:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 05:57 |
