Bizarre behavior of passing a scalarField to another scalarField
Old   October 24, 2020, 20:08
Default Bizarre behavior of passing a scalarField to another scalarField
Reviewer #2
randolph is on a distinguished road
I run into some bizarre behavior of passing a scalarField to another scalarField and I can not explain.
I was try to simply pass a scalarField of Y_pre to scalarField of Y. Initially, I just use
Y = Y_pre
But this does not correctly pass the value to Y. I end up with this following solution.
forAll(Y,celli)
    Y[celli] = Y_pre[celli];
My question is what is the difference between these two method? For additional information, there is a YEqn following right after these two different operation.
Thank advance for any insight.
Rdf
randolph is offline   Reply With Quote
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 08:31
Passing ScalarField from OpenFoam to Fortran IvanaS OpenFOAM 5 April 19, 2013 10:32
