Urgent, trouble with mesh decomposition method on Ubuntu WSL
Old   October 19, 2020, 03:58
Default Urgent, trouble with mesh decomposition method on Ubuntu WSL
Huy Quang Dong
cunconbkhp is on a distinguished road
Hello all,
I hope to get some help with my case's setting.
I'm trying to apply the blastfoam solver for my simulation.
I'm running openfoam 7 on ubuntu 20.04 WSL 2.
my desktop have 20 sockets (40 CPUs) with 64 Gb ram.
I've started with a simple tutorial case (3D Buildingworkshop from blastfoam tutorial) where the meshing is doned with snappyhexmesh for a L Wall.
I've run the tutorial in parallel mode with scotch mesh decoposition methos and everything was fine (fo 1000 ms of explosion).
When i replace the simple wall with my geometry : a close compartement with some window to evacuate the overpressure wave, the simulation is always crashed. For this case, i need to simulate at least 500 ms of explosion but the best time i have before the crash thing happens is 120 ms.
No source of error to dig in, just some info like below :
Calculating Fluxes
max(p): 533983, min(p): 36334.3
max(T): 1741.93, min(T): 240.857
ExecutionTime = 18064.9 s ClockTime = 18175 s
Mean and max Courant Numbers = 0.069117 0.689002
deltaT = 7.69231e-06
Time = 0.0154076923077
Selected 15422 cells for refinement out of 2024383.
Refined from 2024383 to 2132337 cells.
Selected 14528 split points out of a possible 129288.
Unrefined from 2132337 to 2030641 cells.
Calculating Fluxes
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 0 with PID 0 on node F20-5245-4 exited on signal 9 (Killed).
The checkMesh is ok. I've try others decoposition method (simple, hierarchical) but the simualiton is always crashed.
Maybe the error come from the boundary condition. However with the same boundary condition, the tutorial case runs well.
Which is the best way to decompose mesh in openfoam with a complicated structure inside the domain. Here the strcuture from stl is not meshed, just cut out from the mesh block and all the wall will become type wall in the simulation. Is there and caution for the decomposition of complicated wall over many meshes?
My case is attached. Thanks in advance!
File Type: zip Allrun.zip (373 Bytes, 1 views)
cunconbkhp is offline   Reply With Quote
blastfoam, decomposed mesh, decoposepar, scotch
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[ICEM] Need urgent help for hybrid mesh generation Pursuor ANSYS Meshing & Geometry 1 August 29, 2012 17:04
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
